Problems with 12F675
Results 1 to 40 of 67
    Default Icl 7663
    That 10µA or less quiescent looks really nice.
    Is there something like that in a fixed voltage TO-92, so fratello can just stick one in his PC board?
    Talking
    Hi, Darrel
    LP 2950 ACZ 5.0 from National, i.e.???
    regards
    Dec 2008
    Ploiesti, ROMANIA
    Default It is not correct ; why ?
    I try to put another 'tips' in the code of this button.
    At start ( plus by auto's contact) the PIC read from eeprom the value of overrload (variable "calibra"). If this is zero or less than minimum value (setting by me at 270 mV) start subroutine "calibration:". The value of maximum tension reading here are memorized as new value for "calibra".
    One new start : the value of calibra is NOT zero or less than minimum value, so the module works as usual.
    It's correct the code ? I think it's something wrong with reading/writing "calibra" from eeprom ?!? How write correct value of "calibra" in eeprom ?
    Dec 2008
    Ploiesti, ROMANIA
    I made some experiments ; the window roll-up (or roll-down) in about 6 seconds. I'm thinking to something like this :
    eeprom 0, [0, 0]
    read 0, calibra.byte0
    read 1, calibra.byte1
    if calibra =0 then
    high rel1
    ....read U for maximum 7-8 seconds
    ....identify the highest value of U
    ....write this value in eeprom for further using as max.value in check:
    low rel1
    ....etc,etc.
    Help, please, with the red lines; starting with what ? I use "search" but perhaps not so good ; I can't find one "clue" ! Thanks for supporting me !
    Dec 2008
    Ploiesti, ROMANIA
    I read about MAX. It's this correct :
    if calibra =0 then
    high rel1
    gosub calibration
    calibration:
    for cnt=0 to 80
    adcin 3, v_cal
    v_cal=v_cal * 5000
    v_cal=div32 1023
    vmax=vmax max v_cal
    next cnt ' reading v_cal for about 8 seconds ?
    endfor
    low rel1
    calibra=vmax
    calibra.highbyte = ADRESH
    calibra.lowbyte = ADRESL
    write 0, calibra.byte0
    write 1, calibra.byte1
    Thanks for any advice !
    L.E.: The problem is : writing vmax ( example: 275) to eeprom, and then reading.
    Dec 2008
    Ploiesti, ROMANIA
    This is my working code :
    calibration:
    rel1=1 ' rel1 = 1 -->> window roll-up !
    for cnt=1 to 80 ' assuming window roll-up complete in 8 seconds !
    adcin 3, v_cal
    v_cal=v_cal * 5000
    v_cal=div32 1023
    vmax=0 max v_cal
    next cnt
    low rel1
    calibra = vmax
    if calibra > 20 then ' "20" is value knowing by user !
    write 0, calibra.byte1
    pause 10
    write 1, calibra.byte0
    pause 10
    calibra = 19
    pause 10
    pause 10
    Dec 2008
    Ploiesti, ROMANIA
    The value for long press button it's a little to big. I want to reduce him. So,
    Please, help :
    Timer1 = 3037 ' 1 second
    Timer1 = ? ' for 0.5 sec
    ' for 0.6 sec
    ' for 0.7 sec
    ' for 0,8 sec
    Thanks !
  1. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  2. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  3. 12F675 cant serout to PC
    By ruijc in forum General
    Last Post: - 3rd December 2007, 01:11
  4. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 22:45
  5. Serial LCD on 12F675
    By anj in forum mel PIC BASIC Pro
    Last Post: - 1st April 2004, 00:11
