Problems with 12F675
Results 1 to 40 of 67
    Dec 2008
    Ploiesti, ROMANIA
    Hi Mr.Darrel !
    Maybe I can't explain verry clear !
    If @SLEEP command is 'enable', the repause current is 2.5 mA (like without PIC !). But, after couple of press of but1 or but2, but1 don't work more ! Need to disconnect power !
    If @SLEEP is 'disable' (by ' in front of her), the repause current is 3.5 mA, and but1 and but2 works without problems ! I do not change nothing in schematic !
    Just use @SLEEP (2.5 mA ; problems with but1) or not (3.5 mA ; not problems)
    Sorry for my poor english...
    Your problems are NOT in the program, since the same program is running here without any problems.
    What is that part I pointed to above?
    Where are the Flyback diodes for the relay coils?
    Where are the capacitors ... decoupling, and on the regulator?
    Dec 2008
    Ploiesti, ROMANIA
    The regulator is ST78L05, with 1x0.1 uF decoupling on output (SMD,on the back side) ; the diodes for relays are 1N4007 (on the back side). Thanks for patience !
    Hi Fratello,
    I think what Darrel is saying is the 3ma you are measuring is going out through the regulator as HEAT, and your circuit is working as expected.
    Question, if this is a power window switch, do you shut off it's power with the ignition ? You lose more than 3ma because the top of the battery is not clean, and you cannot clean it well enough to not lose it.
    Dec 2008
    Ploiesti, ROMANIA
    I put one capacitor of 1uF to output of 78L05 and I replace the two diodes from relays with 1N4148, and ...YES !!!!!! Now the consumption is 2.5 mA and BOTH buttons work VERRY WELL !!!!! What a simple solution !!!! I can't explain why now work, but I'm HAPPY ! THANK YOU ALL SO MUCH !
    ...now I have in mind another thing : at the first start of this module, reading the current of overrload and memorized him in eeprom, for using as reference for further decoupling of relays. I read about this first 'calibration' in "12F675 Voltage monitor" by Frank Miller. Now I don't know how reading the highest level of voltage assuming the variation of tension is something like this ...
    PS : Hope not making mistake if I bring here this new subject...
    PS2 : A new observation : It's enough to put 1 uF capacitor; don't need to replace the two diodes on relays ! I try this on the other module.
    Wink
    Hi, Fratello
    you should try the ICL 7663 as a regulator, instead of the 78L05 ...
    quiescent current is ... rather interesting !!!
    Default Icl 7663
    That 10µA or less quiescent looks really nice.
    Is there something like that in a fixed voltage TO-92, so fratello can just stick one in his PC board?
  1. 12F683 vs 12F675.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 11th July 2009, 05:58
  2. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
  3. 12F675 cant serout to PC
    By ruijc in forum General
    Last Post: - 3rd December 2007, 01:11
  4. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 22:45
  5. Serial LCD on 12F675
    By anj in forum mel PIC BASIC Pro
    Last Post: - 1st April 2004, 00:11
