clap switch
Results 1 to 2 of 2
Thread: clap switch
    Jun 2006
    Default clap switch
    need help want to turn on a light with the clap of the hand well versed in pic 16f84a20p
    the problem is the minute voltage (50mv) from the the mic driver circuit is there a way to use this voltage to input threw a pic pin to turn on another
    thanks to any smarter minds than mine
    andrew
    Solution 1. Use an amplifier to increase the signal level to something that the PIC Input will trigger on.
    Solution 2. Pick a PIC with internal Comparators (easiest) or ADC (a little more tricky) which can then work with signal levels down in the range you have got.
  1. counting switch events beginner
    By mrpete in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 17:08
  2. a switch and 2LED
    By win_832001 in forum mel PIC BASIC
    Last Post: - 11th October 2006, 23:06
  3. Newbie - 16F628A and switch latching
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 03:35
  4. Switch Sequence
    Last Post: - 13th February 2005, 21:36
  5. Switch Polling vs Interrupts
    By eric blair in forum General
    Last Post: - 17th October 2003, 10:38
