Convert long binary number to ASCII Decimal
Results 1 to 7 of 7
    May 2008
    Italy
    Variables
    W               var Word [8]      ' words array
    Tcount          var Word          ' timer count
    Ocount          var word          ' OverFlow timer count
    A0              var byte          ' general purpose variable
    W[0] = (Ocount * 5) + Tcount dig 4
    W[1] = (Ocount * 3) + Tcount dig 3 + W[0] dig 1
    W[2] = (Ocount * 5) + Tcount Dig 2 + W[0] dig 2 + W[1] dig 1
    W[3] = (Ocount * 5) + Tcount Dig 1 + W[0] dig 3 + W[1] dig 2 + w[2] dig 1
    W[4] = (Ocount * 6) + Tcount Dig 0 + W[1] dig 3 + W[2] dig 2 + W[3] dig 1
    W[5] = W[2] dig 3 + W[3] dig 2 + W[4] dig 1
    W[5] = W[3] dig 3 + W[4] dig 2 + W[5] dig 1
    W[6] = W[4] dig 3 + W[5] dig 2 + W[6] dig 1
    W[7] = W[5] dig 3 + W[6] dig 2
    For A0 = 7 to 0 step -1
    'Display W[A0] Dig 0
    Next A0
    This code (not tested) should add up (overflow number x 65535) and timer counter and distribute the result into the array in position 0 the number (digit) to be displayed.
    Just run a for/next cycle with W[x] Dig 0 and you should display your number on your 8 digits display.
    If you need the ascii value then you have to add 48 to every single digit in the for/next loop.
    Al.
    Thanks all!
    Aratti, I ended up using your algorithm, but I fixed a few errors to make it work. Here's the code I ended up with:
    W[0] = (Ocount * 6) + Tcount dig 0
    W[1] = (Ocount * 3) + Tcount dig 1 + W[0] dig 1
    W[3] = (Ocount * 5) + Tcount Dig 3 + W[0] dig 3 + W[1] dig 2 + w[2] dig 1
    W[4] = (Ocount * 6) + Tcount Dig 4 + W[1] dig 3 + W[2] dig 2 + W[3] dig 1
    W[6] = W[3] dig 3 + W[4] dig 2 + W[5] dig 1
    W[7] = W[4] dig 3 + W[5] dig 2 + W[6] dig 1
    Thanks again
    Joe
    May 2008
    Italy
    I was sure some adjustment was going to be necessary since I didn't tested it.
    Al.
  1. How to convert binary to decimal?
    By Cabomba in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 01:27
  2. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 21:09
  3. Decimal to Binary Conversion
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2006, 14:58
  4. Decimal to binary conversion
    By Demon in forum Code Examples
    Last Post: - 25th February 2005, 20:05
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 20:02
