Help with remote control
Results 1 to 4 of 4
    Jul 2009
    Question Help with remote control
    Hello everyone, I'm trying to build a simple remote control but I am beginner in programming and need help ...
    Please note, I read a value between 0 and 5 volts and then transmitted via the RF result of AD conversion ...
    Believe me, worked ... However the battery discharges very fast ... I need the transfer happen only with a change in the result of conversion ...
    I am using this code:
    @ DEVICE PIC12F683,FCMEN_OFF
    @ DEVICE PIC12F683,IESO_OFF
    @ DEVICE PIC12F683,BOD_OFF
    @ DEVICE PIC12F683,CPD_OFF
    @ DEVICE PIC12F683,PROTECT_OFF
    @ DEVICE PIC12F683,MCLR_OFF
    @ DEVICE PIC12F683,WDT_OFF
    @ DEVICE PIC12F683,INTRC_OSC_NOCLKOUT
    OSCCON = %01100000
    TRISIO = %00001111
    GPIO = %00000000
    WPU = %00000000
    OPTION_REG = %10000000
    ANSEL = %00000001
    VRCON = %10101100
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    adpot var byte
    start:
    ADCIN 0, adpot1
    serout 5, 1200, [adpot]
    pauseus 200
    goto start
    _Somebody help me?
    If I understood correctly:
    OSCCON = %01100000
    TRISIO = %00001111
    GPIO = %00000000
    WPU = %00000000
    ANSEL = %00000001
    VRCON = %10101100
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    adpot var byte
    dummy var byte
    start:
    dummy = adpot
    ADCIN 0,adpot
    if adpot = dummy then start
    serout 5,1200,[adpot]
    pauseus 200
    goto start
    I did NOT compile or test this, it serves as an idea as to what to do, rather than example
    Dec 2005
    Default Been there, done that
    I doubt that limiting the transmissions will make much difference in battery life. You need to calculate the current for the PIC and determine the maximum life given the mAH rating of the battery.
    PAUSEUS does not put the PIC into low power mode. You would do better using the watchdog timer and putting the PIC to SLEEP (using ASM) between readings. But, you really need longer periods at ultra low power to make much of an impact on battery life.
    Also, the type of battery makes a difference. BR type lithium cells retain near rated voltage until just before falling off rapidly while most other types have a steeper discharge curve so that they fall below useful levels much earlier.
    Jul 2009
    Thumbs up
    Sorry friends, looking closely i see the error it made, if the TX stop for any reason the device is lost and is not good ...
    So I followed the advice of "DHOUSTON" and rethink about the batery and limits. Thank you for your attention.
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 20:52
  2. Newbie remote control question?
    By Clodoaldo in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 17:20
  3. IR Remote Control Issues
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 14:12
  4. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 13:26
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 15:13
