Hi! I have been trying to make an interface between 16f877 and ps/2 keyboard but although I have connected the data and clk pins to PB.7 and PB.6 , I cannot see anything on my glcd.
Should I connect these pins with any pullup resistors from 5V or what shoud I do ??
I'm writing my codes below.. Pls help me!
Thans A Lot....
		Include "PROTON18_452.BAS"
Device 16F877
		WARNINGS = OFF
 TRISB=%0110000
Symbol  Giris  PORTB.6
Symbol  Clk    PORTB.5
Dim dur As Bit
    Dim ComingData As Byte
    Dim B0 As Byte
    Dim xpos As Byte
    Dim ypos As Byte
    Dim OKU As Byte
    Dim ADRS As Word
    Dim TEKRAR As Word
    Dim ARRAY1[9] As Byte
    Cls
   BEGIN:
Dim i As Word
For i = 0 To 10 Step 1  '11 bitlik veri gelecek
While Clk =1    ' Ilk önce Clock=1 olmali
Wend
If i<9 & i>0 Then
ARRAY1[i]=ComingData
EndIf
While Clk = 0
Wend
While Clk = 0
Wend
Next
Cls
Print At 2,2, Str ARRAY1
DelayMS 500
GoTo BEGIN
    Include "FONT.INC"
second part of the code for initalize GLCD ... There isn't any error..
' PROTON board for 16 series device
' Operating on 4MHz.
' Using a GRAPHIC LCD with an internal FONT
Device 16F877
        XTAL 4
        TRISB=%11010000
        TRISA=%00000110
        PORTB=0
        LCD_DTPORT = PORTD
		LCD_RSPIN = PORTC.1
		LCD_ENPIN = PORTE.0
		LCD_RWPIN = PORTC.0
        LCD_CS1PIN = PORTE.1
		LCD_CS2PIN = PORTE.2
        LCD_TYPE = GRAPHIC
		INTERNAL_FONT = On
		FONT_ADDR = 0
		SDA_PIN = PORTC.4
		SCL_PIN = PORTC.3
		SERIAL_BAUD = 2400
		RSOUT_PIN = PORTC.6
		RSOUT_MODE = TRUE
		RSOUT_PACE = 1
		RSIN_PIN = PORTC.7
		RSIN_MODE = TRUE
        HSERIAL_BAUD = 2400		' Set baud rate to 2400
        HSERIAL_RCSTA = %10010000       ' Enable serial port and continuous receive
        HSERIAL_TXSTA = %00100100       ' Enable transmit and asynchronous mode
        HSERIAL_CLEAR = On		' Enable Error clearing on received characters
		'KEYPAD_PORT = PORTB
        CCP1_PIN = PORTC.2
		CCP2_PIN = PORTC.1
		Symbol T300 = 3313	NO_LIST
		Symbol N300 = 3313 + $4000	NO_LIST
		Symbol T600 = 1646	NO_LIST
		Symbol N600 = 1646 + $4000	NO_LIST
		Symbol T1200 = 813	NO_LIST
		Symbol N1200 = 813 + $4000	NO_LIST
		Symbol T2400 = 396	NO_LIST
		Symbol N2400 = 396 + $4000	NO_LIST
		Symbol T4800 = 188	NO_LIST
		Symbol N4800 = 188 + $4000	NO_LIST
		Symbol T9600 = 84	NO_LIST
		Symbol N9600 = 84 + $4000 NO_LIST
		Symbol OT2400 = 396 + $8000	NO_LIST       ' Open True
		Symbol OT1200 = 813 + $8000	NO_LIST       ' Open True
		Symbol OT9600 = 84 + $8000	NO_LIST      ' Open True
		Symbol OT300  = 3313 + $8000	NO_LIST      ' Open True
		Symbol ON2400 = 396 + $4000 + $8000	NO_LIST      ' Open Inverted
		Symbol ON1200 = 813 + $4000 + $8000	NO_LIST      ' Open Inverted
		Symbol ON9600 = 84 + $4000 + $8000	NO_LIST      ' Open Inverted
		Symbol ON300  = 3313 + $4000 + $8000 	NO_LIST     ' Open Inverted
' Rsout / Serial Constants
		Symbol HOME = 1	NO_LIST
		Symbol BELL = 7	NO_LIST
		Symbol BKSP = 8	NO_LIST
		Symbol TAB = 9	NO_LIST
		Symbol CR = 13	NO_LIST
        ALL_DIGITAL = True	' Set PORTA and PORTE to all digital
