Creating Bespoke output waveform
Results 1 to 7 of 7
    This is not very difficult:
    you need to use two outputs : one for positive output and one with an OPA as an inverter ( gain = -1 ) for negative output.
    Of course a negative supply is needed ... think to max 232, ICL 7660 or similar as the negative voltage generator ... if no output power is needed.
    BTW ... which is the final use ??? already done designs surely exist ... ( electrical stimulators, i.e.)
    There is no need for an OPA or two PIC outputs.
    One RS232 level convertor chip should do the trick. All you need to keep in mind is the inverted logic.
    HTH
    Nick
    Wink
    Quote Originally Posted by Nicmus View Post
    HTH
    Nick
    Ok for + 5 and -5 v ... ( better say +12 and -12 ); BUT ... How do you produce the 0 v level, then ???
    The RS 232 third state, I presume ???
    My bad. I only got Adam’s written request: swing from positive 5V to negative 5V with no need for 0V as shown in the waveform.
    There are few RS 232 chips that have control pins (EN if I’m not mistaken) that will cause the outputs to go in three-state mode.
    In this case a pull down resistor and one more PIC IO should be enough.
    Nick
    Jul 2009
    Nick
    Thanks for all the help! I do need the zero fault state as this is where the signal needs to start and finish, quite right though, I didn't mention this in the original posting. I'll have a look at the RS232 option and see how I get on...
    Here is a link to Maxim site:
    http://datasheets.maxim-ic.com/en/ds/MAX220-MAX249.pdf
    Nick
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
