Eeprom
Results 1 to 3 of 3
Thread: Eeprom
    Jun 2009
    Lagos Nigeria
    Talking Eeprom
    Am confuse about certain things involves eeprom sometimes at work damaged.
    I have this question;
    A: Reusing eeprom from condemned car radio do it have affect on new replaced?
    B: Eeprom programming any manual for it?prom
    C: Can one get pdf of eeproms and diagrams.
    Peace
    Apr 2006
    Alberta Canada
    It all depends... If i understand your question, then:
    A: you want to use EEPROM out of old equipment. As long as its not the reason you car audio stopped working, it should be ok. EEPROM has a certain lifespan of read/write cycles and depending on how many times its been written too, it might not last much longer.
    B: to use your EEPROM, you would have to get the numbers off the top of the chip, and google it until ou find the datasheets. they will tell you everything you ever need to know about that particular EEPROM.
    C: Same as B. Get the numbers off of the chip, and look it up online.
    Jun 2009
    Lagos Nigeria
    Talking Advise
    Yes is eeprom from damaged car radio now what i need is diagram how voltage pass in and out of it.
    Peace
    Last Post: - 18th February 2010, 14:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 19:59
