adc temperature sensor
Results 1 to 13 of 13
    rastan's Avatar
    rastan Guest
    Wow, ive come a long way since then and I had even forgot that I ever did this!
    As for the circuit, I think its best if you try and figure it out on your own. If you are not comfotable about designing a circuit for this then you are obviously not ready to try some thing 'this' complicated.
    Why not try a flashing light excersise first? And then maybe a A/D conversion from a potentiometer. And then get an LCD going. They are usually the best ways to go. From there It is possible to simply replace the Potentiometer for the LM35Z and vuala.
    Phil
    johor,Malaysia
    thank for help.
    i success build this project.
    very very thank for all and rastan...
    thank for your code
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Precision Temperature Sensor
    By Normnet in forum Off Topic
    Last Post: - 8th March 2010, 15:48
  3. 18B20 temperature sensor and PIC
    By boban in forum Schematics
    Last Post: - 4th June 2007, 14:51
  4. Precise temperature sensor
    By Christopher4187 in forum Off Topic
    Last Post: - 7th June 2006, 19:39
  5. read temperature sensor
    By breeno in forum General
    Last Post: - 10th January 2005, 07:04
