rs232
Results 1 to 21 of 21
Thread: rs232
    Jun 2009
    Default rs232
    hi ive connected a gps unit up direct to my serial port via a max232 chip
    but i'm only seeing the nmea string when i toggle the power on and off to the rs232 chip, anyone have any idea why this is
    i'm using the attached schematic
    i did have the unit connected to a pic micro waiting for a particular nmea string so i could parse it but the pic wasn't seeing anything, so thought i would connect it directly to the serial port just to see if its outputting anything
    I missread that. Do not use an inverter chip with the gps.
    It is not needed with the PC and post your code too.
    Oops, This is assuming you mean that you are connecting your gps to your PIC chip, and not your computer. If you are just connecting your gps to your computer, no need for a max232 chip.
    I've used the max232 chip with gps before. If you are using a standard GPS to PC serial cord, you will need to either swap your wires 7 and 8 on the max232 chip, or insert a null modem adapter on your gps cable.
    http://www.scalerobotics.com
    Jun 2009
    hi
    sorry if my original post was confusing i typed it in a rush lol
    first of all i connected my gps unit directy to a pic micro then using serin2 and wait, i waited for a particular nmea sentence to parse it etc, and the pic was just waiting it never could see even a $ sign coming from the gps unit,
    so then...
    got rid of the pic and i connected the gps unit directly to my pc's serial port via an rs232 chip, and viewed the data via microcode studio serial communicator
    but the data would only be sent to the pc when i applied and removed power to the rs232 chip repeatedly if that makes sense.
    below is the basic code i created just to see if the gps unit was transmitting data to the pic.
     @ device  pic16f870,WDT_OFF            'Watch Dog Timer Disabled
     @ device  pic16f870,PROTECT_OFF        'Code Protect Off
     @ device  pic16f870,XT_OSC             'Using External Oscillator
     @ device  pic16f870,BOD_on            'Brown Out Timer Disabled
     @ device  pic16f870,PWRT_on          'Power On Timer Disabled
     @ device  pic16f870,LVP_OFF            'Low Voltage Programmed Disabled
    define OSC 20
    'TRISA = %11111111
    'TRISC = %00000000
    'ADCON0.0=0
    'ADCON1=7 ' ALL PINS SET TO DIGITAL
    'Pin Assignments
    GPIO0 VAR PORTA.0
    NC VAR PORTA.4
    TX var portb.5
    RX VAR PORTA.2
    Reset var porta.1
    GPIO4 var porta.5
    'Variables
    gps_data var byte
    HIGH PORTC.0
    PAUSE 200
    LOW PORTC.0
    PAUSE 200
    SEROUT2 PORTC.1,16468,["GPS TEST$123456"]
    pause 500 'allow gps module to init
    'if gpio4=0 then high portc.3'(red)
    reset_unit:
    low reset
    high reset
    MAIN:
    serin2 TX,16468,[WAIT("$GPGGA"),str gps_data\6]
    PAUSE 200
    HIGH PORTC.0
    PAUSE 200
    LOW PORTC.0
    PAUSE 200
    SEROUT2 PORTC.1,16468,[str gps_data\6]
    GOTO MAIN
    Sounds about right for the PC, data getting through as the
    232 chip was powering up and down.
    232 chip is not needed with the PC and if you are
    using SERIN2 then run the PIC in inverted mode.
    Keep it simple...
    Jun 2009
    Keep it simple...
    are you talking about communicating from the pic to the pc, in this instance i was not using a rs232 chip, but when soley connecting the gps unit directly to the serial port i was using a rs232 chip if i bypassed the chip i just got garbage on the screen.
    Now I think I may see the problem. I will assume your GPS unit sends data at 4800?
    Here is a snippet from one of my programs. No 232 chip.
    SERIN2 PORTB.1,16572,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S,_
            WAIT(","),DEC2 ND,DEC2 NM,WAIT("."),DEC3 NMD,WAIT(",N,"),_
            DEC3 WD,DEC2 WM,WAIT("."),DEC3 WMD]
    Jun 2009
    according to the datasheet its 9600
    would my test code work tho were i input the next 6 characters afer "GPGGA"
    then use serout2 str gps_data\6] would str gps_data\6 show the next 6 characters even it was a comma or dollar sign etc?
    It should work.
    can you post the data sheet for the GPS module you are using
    Jun 2009
    datasheet attached.
    Mar 2004
    UK-Midlands
    As it runs off 3.3v here is a PDF on interfacing it. Hope it helps.
    http://www.crownhill.co.uk/datasheets/ZX4120%20GPS.pdf
    Bob
    Jun 2009
    Quote Originally Posted by BobP View Post
    Bob
    hi,
    i've got the pdf and ive refered to it alot when i got stuck, thats y i can't understand why its not working hmmm
    Quote Originally Posted by rondo2 View Post
    gps_data var byte
    Your gps_data is defined as a single byte. You want an array to work with, so you should define it as something like:
    gps_data var byte[6]
    Jun 2009
    hi thanks for pointing that out but still nothing.
    i changed my code to serin2 TX,84,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S]
    PAUSE 200
    HIGH PORTC.0
    PAUSE 200
    LOW PORTC.0
    PAUSE 200
    SEROUT2 PORTC.1,16468,[dec2 H, dec2 M, dec2 S]
    GOTO MAIN
    still nothing
    the gps module is connected properly it is receiving 3.3v so unsure whats going on
    do you no if it must have a backup battery, because at the moment i don't have that pin connected to anything
    What's your hardware setup? Got a picture? Can you show the whole code? I wonder what your TX pin is doing with the serial in, but I can't tell from here.
    The code you just posted is not inverted, so I assume you have the max232 back in?
    Jun 2009
    hi
    my brother has my cam at the moment, i will get it off of him tomorrow.
    quick question - i'm using a 16F870 will it accept voltages as low as 3.3v on an I/O pin
    Apr 2006
    Alberta Canada
    What does C.0 do? does it flash an LED?
    if its used for something else, then it might be a good idea to ad an LED and make it flash on and off as your program runs. I find that it helps me know where the program is getting hung up or if its running at all..
    One other thing, and im not sure if its right or not, but wheni use an external osc i need to set it to HS not XT.
    Jun 2009
    Quote Originally Posted by dragons_fire View Post
    hi yes portc.0 is used to flash an led, so i know its recieving serial data.
    the pic micro it self is running as it output's a test message to the pc's serial port and that is sent fine
    Jun 2009
    Also
    i measured the voltage on the pin which transmits the serial data fron the gps module, and it was only 1.5v, now is that normal.
    the pic micro will not see the data at such low levels will it ?
    Data Sheet: "Wide operating range 2.0 to 5.5v . . . " I would make my own headaches small and run the
    pic and gps on 3.3v, 1 supply 1 headache 2 supplies 2 . . .
    Also
    3 ways to get fish, buy fish, learn to fish, beg fish at the dock ... to learn to fish you have to observe others
    even if their fishing is not what you want today. I mean by this, read posts that do not apply to what you are doing today <br>
    Look at the GPS data sheet, it's pretty thin I admit. Your GPS unit communicates @ 9600 b True, which means it is
    "active low" as stated in the data sheet. This means it does not supply +5 or +3.3 on that port. Where does it get it? From the
    pullup resistor, you are going to put on that line to the 3.3v supply. True requires a pullup whereas Inverted
    would like to idle low with a pulldown.
    i changed my code to serin2 TX,<font color = red>84</font color>,[WAIT("$GPGGA"),WAIT(","),DEC2 H,DEC2 M,DEC2 S]
    PAUSE 200
    HIGH PORTC.0
    PAUSE 200
    LOW PORTC.0
    PAUSE 200
    GOTO MAIN
    84 sets serin2 to Driven true 32852 sets it to open true. Try the open true setting
    turn this OFF until everything else works and turn on PWRTE ON, it just gives the power supply a little time to stabalise before the PIC boots
    I honestly do not if this will cause problems given your 20 mhz define, since you are using an external OSC, but why chance it ?
    I would make it HS, might not change anything, except you will know for sure that is NOT a problem.
    Jun 2009
    Quote Originally Posted by Joe S. View Post
    HI Joe,
    the open true serial settings fixed it
    thanks a lot
  1. Universal remote and Rs232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th February 2010, 18:55
  2. UART vs software RS232
    Last Post: - 5th September 2008, 19:27
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  5. RS232 to Weigand
    By Stevenindon in forum Serial
    Last Post: - 6th April 2006, 05:35
