need help for APR6008 SPI interface
Results 1 to 6 of 6
    Bombay, India
    Hi Mahesh
    I've not used this particular part, but have used the APR48000 and another similar one. The code is in 8051 C, but if it helps, I have attached it here.
    		APR48000 voice record/playback IC routines
    /* Send a command to the APR48000
      Cmd is the APR Opcode
    	Adr is the parameter for the opcode
    	Send order is Msb-Lsb
    	   First the Cmd (Lower 6 bits), then Adr (Lower 15 bits)
    	PWRUP (4) (0x2)
    	REC   (9)
    	PLAY  (D)
    	FWD   (3)
    	STOP  (6)
    void	CommandAPR(byte Cmd, uint Adr) {
    byte BitCnt;
    	Cmd <<= 3;
    	Adr <<= 1;
    	APRcs = 0;
    	for (BitCnt = 0;BitCnt < 5;BitCnt++){
    		APRdi = Cmd & 0x80;
    		APRclk = 1;
    		Cmd = Cmd << 1;
    		APRclk = 0;
    	for (BitCnt = 0;BitCnt < 15;BitCnt++){
    		APRdi = Adr & 0x8000;
    		APRclk = 1;
    		Adr <<= 1;
    		APRclk = 0;
    	APRcs = 1;
    Mar 2007
    Mumbai-INDIA
    Smile
    Thank you norm for your reply. Its an interesting project.
    Dear Jerson can I request you to help me convert the code into PBP. Trust me it will help many others like me. Hope u will find some time for it.
    regards
    Mahesh
    Bombay, India
    I think it is quite straight forward. Anyway, here goes. Unchecked, untested, use at your own risk and consequence
    ' Send a command to the APR48000
    '       APR_Cmd is the APR Opcode
    '	APR_Adr has the parameter for the opcode
    '	Send order is Msb-Lsb
    '	   First the Cmd (Lower 6 bits), then Adr (Lower 15 bits)
    '	PWRUP (4) (0x2)
    '	REC   (9)
    '	PLAY  (D)
    '	FWD   (3)
    '	STOP  (6)
    APR_cs         var  PORTA.0  ' define your own
    APR_di         var  PORTA.1   ' define your own
    APR_clk        var  PORTA.2   ' define your own
    APR_Cmd     var  byte
    APR_Adr       var  word
    BitCnt:          var  byte
    CommandAPR:
            APR_Cmd = APR_Cmd << 3
            APR_Adr = APR_Adr << 1
    	APR_cs = 0;
            for BitCnt = 0 to 5
    		APR_di = APR_Cmd.7
    		APR_clk = 1;
                    APR_Cmd = APR_Cmd << 1         ' remove the bit we transferred
    		APR_clk = 0;
            next
            for BitCnt = 0 to 15
    		APR_di = APR_Adr.15  'unsure of this instruction
    		APR_clk = 1
    		APR_Adr <<= 1                            ' remove the address bit transferred
    		APR_clk = 0
            next
    	APRcs = 1;
    Mar 2007
    Mumbai-INDIA
    Smile
    Dar Jerson,
    Thank you for helping me getting started, appreciate your time.
    mahesh
  1. Master SPI interface to LCD/OLED??
    Last Post: - 20th September 2009, 00:44
  2. Weird SPI interface: VIH to VIHH for CS?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 18:25
  3. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 16:42
  4. Help with MicroMag3 SPI interface to PIC
    By kaan in forum mel PIC BASIC Pro
    Last Post: - 1st June 2006, 00:20
  5. How to read a SPI serial interface
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2005, 05:14
