RPM With Timer1
Results 1 to 15 of 15
Thread: RPM With Timer1
    Jun 2006
    Default RPM With Timer1
    I'm using a 16f687 and trying to get the timer1 working. I'm using a code snipet from mister e. It works great with a 16f688 but can't get it to work with the 16f687.
    @wTimer1 = TMR1L
    wTimer1 var word EXT ' timer1 setup
    Speed:
    wTimer1=0 ' clear Timer1
    T1CON = %00000111 ' start timer1
    pause 1000 ' acquisition time
    T1CON = %00000110 ' stop timer1
    The rest of the code works fine just this part doesn't. Also if I change wtimer1 to 4 it displays the 4 so I know it's getting here??????
    Do you have an external clock input on T1CKI? You have Timer1 configured
    for external clocks.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2006
    Yes on RA5, sorry forgot to put that.
    I can't see anything in the small code fragment you posted that
    would keep Timer1 from counting.
    Assuming you have pulses on RA5 during your pause time - it should
    work the same as on your 16F688. I suspect there's something either
    different in the rest of your code, a bad connection, or a fried pin.
    -Bruce
    tech at rentron.com
    Jun 2006
    I have pulses on RA5 and here's the code.
    Include "modedefs.bas"
    'DEFINES-----------------------------------------------------------------------
    define OSC 4
    'SETUP REGISTERS---------------------------------------------------------------
    TRISA=%110000 'RA4,RA5 as Input
    ANSEL=%00001000 'AN3 Analog In
    ANSELH=$00 'All pins digital out
    TRISB=$00 'All pins output
    TRISC=$00 'All pins output
    CM1CON0.7=0 'Shut off comparators
    CM2CON0.7=0 'Shut off comparators
    ADCON0.7=1 'Right justify result
    'SETUP VARIBLES----------------------------------------------------------------
    DPIN var PORTC.1 ' Shift data pin
    CPIN var PORTC.2 ' Shift clock pin
    LPIN var PORTB.4 ' Latch pin
    adval var word ' Create adval to store result
    volt var byte ' Battery level
    cvolt var byte ' Charge voltage
    lvolt var byte ' Load voltage
    LBatt var byte ' Low battery alarm
    @wTimer1 = TMR1L
    A595 var byte ' Alarm out byte
    C595 var byte ' Charge out byte
    L595 var byte ' Load out byte
    ; Initialize your Hardware first, set CONFIGs, OSC, Turn off A/D etc
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4 VAR PORTC.3
    LCD_DB5 VAR PORTC.6
    LCD_DB6 VAR PORTC.7
    LCD_DB7 VAR PORTB.7
    LCD_RS VAR PORTC.5
    LCD_E VAR PORTC.4
    LCD_Lines CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50 ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    PAUSE 1000 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this,
    ; but some displays are picky)
    Voltsetup:
    lvolt=48 ' Set load dump to 14.8 volts
    cvolt=22 ' Set charge to 12.2 volts
    LBatt=16 ' Set low battery alarm to 11.6 volts
    Start:
    lcdout $FE,1,"RMLDESIGN VER1.0"
    lcdout $FE,$C0," WINDCONTROLLER"
    pause 4000
    lcdout $FE,1
    gosub getad
    adval=adval+100
    LCDOUT $FE,$80,"V=",dec (adval/10), ".", dec adval dig 0
    lcdout $FE,$88,"RPM=",dec4 wTimer1*9
    if volt>cvolt then gosub Load 'On Start Up Put On Load If Volts High
    gosub Speed
    gosub Getad
    adval=adval+100
    if volt<LBatt then Alarm 'Show Low Battery
    if volt>lvolt then Load 'Put charge to load
    If volt<cvolt then Charge 'Charge battery
    Speed:
    Getad:
    adcin 3,adval 'Get A/D value
    if adval> 355 Then adval=355 'Range between 100 & 355 then minus
    if adval< 100 then adval=100 '100 to get 0=10 & 255=35.5
    adval=adval-100
    volt=adval
    Alarm:
    a595=%00001001
    Shiftout DPIN, CPIN, MSBFIRST,[A595] ' send byte to 74hc595
    pulsout lpIN,10
    high portb.6
    lcdout $FE,$C0,"*LOWBATT CHARGE*"
    Load:
    l595=%00100100
    Shiftout DPIN, CPIN, MSBFIRST,[L595]
    pulsout lpin,10
    high portb.5
    lcdout $FE,$C0," *ON LOAD* "
    Charge:
    c595=%00010010
    Shiftout DPIN, CPIN, MSBFIRST,[C595]
    pulsout lpin,10
    high portb.6
    lcdout $FE,$C0," *CHARGING* "
    It might work once you fix a bunch of errors. Look through your code slowly, line by line.
    if volt>cvolt then gosub Load. This calls Load, but Load doesn't RETURN. It lands on a
    GOTO Main.
    if volt If volt T1CON = %00000111 ' start timer1 ? I'm not sure what this does, but it looks
    pretty odd...;o}
    volt=adval ' volt is a byte. adval is a word?
    Your Main routine has a RETURN instead of a GOTO Main. This, along with the GOSUB Load
    with no RETURN is going to screw up the stack.
    Go through it all slowly. There may be more potential show-stoppers....;o}
    -Bruce
    tech at rentron.com
    Jun 2006
    The only part that doesn't work is the timer1. I have it displying everything except rpm. Timer1 is not counting. As for the if volt statements, all of those lines didn't copy in. They're all there in my code. It's just the Speed part always read 0.
    Why ask for help - if you're not going to listen or learn from it?
    -Bruce
    tech at rentron.com
    Jun 2006
    What do you mean by that????
    Did you fix the problem areas I pointed out above?
    Can you post your code, that's still not working, showing the fixes?
    -Bruce
    tech at rentron.com
    Jun 2006
    Can't post code. It shows everything correct on reply screen then I hit preview post and it jumbles Speed into Main routine?? Tried three times and now I see the if volt if volt deal. Thats because of the jumbling it did.WOW!! Speed: should read as post 1 does.
    Yes, I did go thru and change what you had said. As for the T1CON I didn't change because that is where the problem is. It just displays 0 all the time??This works on the 16f688 but not the 16f687?? On the datasheet T1CON bit 7 I don't understand?? I can't test anymore tonight had to pick up garage for company tonight, but can still read posts.
    Use the code tags when posting code to help keep formatting.
    See this page for an example http://www.picbasic.co.uk/forum/misc.php?do=bbcode#code
    Just replace value with the code you paste into the text area.
    -Bruce
    tech at rentron.com
    Jun 2006
    It's still jumbling the main with speed when I hit preview. It all works except the speed routine.
    Speed:
    T1CON.0=1 ' start timer1
    T1CON.0=0 ' stop timer1
    I call this from a gosub in the main routine. I know it gets here because if I put a number in wtimer1= it will display that number.
    Try placing an LCDOUT just below T1CON.0=0 in your Speed routine to see if it prints
    the value in Timer1.
    Does it work now?
    -Bruce
    tech at rentron.com
    Jun 2006
    Bruce,
    Sorry to waste your time. My fault on that one. Forgot one resistor. Everything works just fine now. Thank you for the help!!!!!!!
    Mike
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2010, 17:12
  2. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 02:29
  3. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 01:40
  4. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 05:33
  5. Code Issue - select case or 'if' issue - not sure why
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 7th October 2007, 09:52
