There are probably a gozillion various ways to do this, but since you're already using GP2, and this pin is the Timer0 clock input, maybe something like this?
' // Internal RC OSC, WDT OFF, /MCLR reset function OFF
@ DEVICE INTRC_OSC_NOCLKOUT,WDT_OFF,MCLR_OFF
DEFINE OSCCAL_1K 1     ' Calibrate internal oscillator
GPIO = 0               ' All outputs to 0
TRISIO = %00000100     ' GPIO.2/T0CKI = input, rest outputs
CMCON = 7              ' Comparators OFF, all digital
' // Pull-ups on, TMR0 clock source = GP2/T0CKI input
' // Increment TMR0 on high-to-low transitions on GP2/T0CKI
' // Assign prescaler to WDT for 1:1 clocks on GP2/T0CKI
OPTION_REG = %00111000
' // Pre-load timer0 to over-flow on 3rd pulse on GP2/T0CKI
TMR0 = 253 ' 1st clk = 254, 2nd = 255, 3rd = over-flow & int
' // Enable global, peripheral & timer0 interrupts
INTCON = %11100000
On Interrupt Goto FireFlash
    @ NOP
    GOTO Main
    DISABLE
FireFlash:
    HIGH GPIO.4 ' Fire flash
    PAUSEUS 500 ' Adjust for time you need to fire flash here
    LOW GPIO.4
    TMR0 = 253  ' Reload for 3rd pulse to trigger int
    INTCON.2 = 0' Reset TMR0 int flag before leaving
    RESUME      ' Re-enable interrupts & return
    ENABLE
