ADCIN query
Results 1 to 3 of 3
Thread: ADCIN query
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default ADCIN query
    Hi all.
    Got a little problem with a project:
    I am reading a single Anaolgue pin, and then sterring a particular LED on depending on the reading
    start:
    adcin 1, instate
    select case instate
    case is>220 'actual is 248
    portb = %00010000
    goto finish
    case is>190 'actual is 201
    portb = %00001000
    goto finish
    case is>162 '178
    portb = %00000100
    goto finish
    case is> 139 '154
    portb = %00000010
    goto finish
    case is<133 '108
    portb = %00000001
    goto finish
    case is >132 and is <140 '136
    portb = %00000000
    goto finish
    finish: end select
    pause 20
    goto start
    The first 5 cases are OK, however when I disconnect the input pin so that it is open circuit, rather than setting all LEDs off, for some reason PB1 turns on. The open circuit reading is not in the range for that, as it is 136 which falls into the 6th case.
    Each reading sith within a particular window, but for some reason there is a hiccup.
    There is a resistor divider and Cap on the input line, and have looked at it on my CRO and can't see any noise on the pin. (anyway, any noise would (should) cause a couple of LEDs to blink?))
    Have tried 'F88, 'F819 and 'C715 in the target PCB and in my development board with the same result.
    Have also sent the reading to an LCD and each shows up as what it should be.
    Any ideas (again?)
    Peter Moritz.
    Peter Moritz.
    New South Wales,
    Australia.
    muddy0409, Try this...
    case is >133
    portb = %00000000
    goto finish
    case is<134 '108
    portb = %00000001
    goto finish
    I have to ask though, Why are you using all of the "goto finish" statements? The case statement takes care of that for you.. The code would run faster with out them...
    Wink
    Hi, Peter
    isn't that a Typo ???
    case is<133 '108
    Cause the written code matches to what you describe ...
    so, Try this one :
    start:
    adcin 1, instate
    select case instate
    portb = %00010000
    portb = %00001000
    case is>162 '178
    portb = %00000100
    case is> 139 '154
    portb = %00000010
    case is >132 '136
    portb = %00000001
    case ELSE '108
    portb = %00000000
    end select
    pause 20
    goto start
    Here, leds will be off for Open input ... if divider present on input !
    PS ... I suppose you mix "break" C statement with PbP " go to Finish " ... lol : PbP do not [no]need[no] have it !!!
  1. ADCIN and PIC18F4331 Arghhhhh !
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 6th December 2010, 21:27
  2. How to make adcin stable?
    Last Post: - 20th January 2009, 08:41
  3. ADCIN Problem
    By JavPar in forum General
    Last Post: - 20th January 2009, 04:36
  4. Adcin or Pot
    Last Post: - 11th January 2007, 17:46
  5. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 08:46
