Using interrupt as an input
Results 1 to 2 of 2
    Jun 2009
    Default Using interrupt as an input
    If I disable the external interrupt on 16F876A, can I use the pin as an input before I re-enable the interrupt? I have an application that has 2 push buttons, and I do not want to add a third just to trigger the interrupt.
    If I understand this... the pin is usually used say with a Sensor triggering an Interrupt when the device is operating (say counting pulses from a weather-vane)... but when in SETUP Mode you also have a Button on the same pin for user entry (presetting Alarms and things)... In that kind of scenario, absolutely no problem. The only thing you have to worry about is somebody inadvertantly pressing the button during normal operation and potentially screwing that up by triggering your interrupt.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
