How to get .hex from this code??
Results 1 to 13 of 13
    Wink
    Right ... definitly a Stamp dinausaur ...
    So just add at the progam top:
    B1 var Byte ' "B" stands for Byte, " W " for Word, ... in the Stamp language.
    B2 var Byte
    care must also be taken Stamp automatically resets variables to zero ... and PbP not !
    I prefer writing it like that for " little RAM " processors ... like my old 16C84s ... than include BSx inc Files ...
    Jun 2009
    thank you for all replys guys.
    after modification of code with:
    include "bs1defs.bas"
    B1 VAR BYTE
    B2 VAR BYTE
    i was able to compile it.
    When i press the coresponding button, servo1 react, but it's bit slow.
    Servo2 doesn't react on button. It's just go full CW and then stop. And sometimes it buzzing.
    Aslo, when i want to turn servo1, servo2 is trying to move.
    But that's probably of shared power supply.
    I will try to rebuilt it.
    Jun 2009
    Actually, all i had to ad to the code was just
    If i tried it with
    B1 VAR BYTE
    B2 VAR BYTE
    i received an error: Redefinition of VAR
    Jun 2009
    One more question. What about Fuses? What should i set for my for that project? I've got MPASM from Microchip.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
