How to get .hex from this code??
Results 1 to 13 of 13
    Quote Originally Posted by Michael Wakileh View Post
    Omission unintentional, please pardon.
    Jun 2009
    Thank you guys for reply.
    Doesn't the code from Listing 3 below have to be somehow modified?
    'Manual control of two servomotors using 2 SPDT switches
    'Use B1 to hold pulsewidth variable for servo 1
    'Use B2 to hold pulsewidth variable for servo 2
    'Initialize Variables
    B1 = 150
    B2 = 150
    'start servo 1 at center position
    'start servo 2 at center position
    start:
       IF pin1 = 0 Then left1
       IF pin2 = 0 Then right1
       IF pin4 = 0 Then left2
       IF pin5 = 0 Then right2
       PulsOut 0, B1
       PulsOut 3, B2
       Pause 18
       GoTo start
    'check for switch closures
    'is sw1 left active?
    'is sw1 right active?
    'is sw2 left active?
    'is sw2 right active?
    'send current servo 1 position out
    'send current servo 2 position out
    'Routines for Servomotor 1
    left1:
       B1 = B1 + 1
       PulsOut 0, B1
       PulsOut 3, B2
       Pause 18
       IF B1 > 225 Then max1
       GoTo start
    right1:
       B1 = B1 - 1
       PulsOut 0, B1
       PulsOut 3, B2
       Pause 18
       IF B1 < 75 Then min1
    GoTo start
    max1:
       B1 = 225
       GoTo start
    min1:
       B1 = 75
       GoTo start
    'increase the pulse width
    'send current B1
    'send current B2
    'set frequency update about 50 hz
    'maximum 2.25 millisecond
    'decrease the pulse width
    'send current B1
    'send current B2
    'minimum .75 millisecond
    'cap max B1 at 2.25 milliseconds
    'cap min B1 at .75 millisecond
    'Routines for Servomotor 2
    left2:
       B2 = B2 + 1
       PulsOut 0, B1
       PulsOut 3, B2
       Pause 18
       IF B2 > 225 Then max2
       GoTo start
    right2:
       B2 = B2 - 1
       PulsOut 0, B1
       PulsOut 3, B2
       Pause 18
       IF B2 < 75 Then min2
       GoTo start
    max2:
       B2 = 225
       GoTo start
    min2:
       B2 = 75
       GoTo start
    Because if i try to compile it with MicroCode Studio - PICBASIC PRO, i'll receive too many errors like:
    ERROR Line 15: Bad expresion. (ser1.txt)
    There are errors almost for each line.
    As i am absolute NOVICE in coding, those errors are bit over my head
    I have seen some codes, where guys had something like:
    #include < blablabla.h >
    Does i need some .h file to be included?
    Right you are. The code looks like it was written for a Basic Stamp Pic Chip. For this, just add the include at the top of your program, then it will compile without errors.
    DEFINE OSC 20       'define crystal speed. This is 20 mhz
    include "bs1defs.bas"    'lets you use definitions same as Basic Stamp 1
    http://www.scalerobotics.com
    Looks like the code may work straight away with MeLabs PBC (Pic Basic Compiler) rather than PBP (Pic Basic Pro).
    Wink
    No,No ... error this code has been written for a 4 Mhz Pic or BS1 ... ( pulsout units are 10µs ! )
    No need any "DEFINE OSC " then ...
    nor "bs1defs" ... as pins are " genuine numbered " by PBP
    Other project error : Pic and Servos MUST NOT share the same supply ... if you want them to work properly ...
    and R2 / R4 might get their supply from +5 v ... NO MORE !
    In other words ... soft may be Ok, as Mel states ... but not Hardw. !!!
    Thanks Alain, good catch on the pulseout.
    But speaking of errors, when I try to compile on PBP without using:
    INCLUDE "bs1defs.bas"
    I get too many errors to compile. It gets stuck on the first mention of variables:
    B2 = B2 + 1
    How do you overcome this with Picbasic Pro, without using the include (and without defining each variable separately)? My manual states I must include "for compatibility sake", and that the include creates "the standard variables used with the Basic Stamps", not to mention that it compiles without errors when I use the include.....
    Wink
    Right ... definitly a Stamp dinausaur ...
    So just add at the progam top:
    B1 var Byte ' "B" stands for Byte, " W " for Word, ... in the Stamp language.
    B2 var Byte
    care must also be taken Stamp automatically resets variables to zero ... and PbP not !
    I prefer writing it like that for " little RAM " processors ... like my old 16C84s ... than include BSx inc Files ...
    Jun 2009
    thank you for all replys guys.
    after modification of code with:
    B1 VAR BYTE
    B2 VAR BYTE
    i was able to compile it.
    When i press the coresponding button, servo1 react, but it's bit slow.
    Servo2 doesn't react on button. It's just go full CW and then stop. And sometimes it buzzing.
    Aslo, when i want to turn servo1, servo2 is trying to move.
    But that's probably of shared power supply.
    I will try to rebuilt it.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
