Thanks. All good stuff. I think we are getting near the limit.
The actual output to the WS2812B 1024 NeoPixel array is handled by the large mixed basic/assembler subroutine below.
I made a couple of small mods so it could work with 1024 leds and one data array holding the LED colour info encoded in bits 5,6,7 and brightness from 0-31 in bits 0-4.
I found brightness of 31 was really bright enough for daytime use and kept power supply requirements within reasonable wall wart limits.
So once the NeoLed array is loaded with the data this routine is called and loops until all 1024 led data has been output.
Code:NeoPixelASM64:'------------- subroutine call name ---------------- POINTER = NEO_NUM - 1 'THIS SCHEME USED TO ELIMINATE USING "< or >" COMPARE STATEMENTS SCRATCH = NEO_NUM - 1 'THIS SCHEME USED TO ELIMINATE USING "< or >" COMPARE STATEMENTS DOGREEN: NeoPixel = SCRATCH - POINTER 'PUSH PIXELS FROM LOWEST to HIGHEST! DON'T ASK ME WHY? NeoPixValue = NeoLed(NeoPixel) 'First, the Green array 'Colours %000 10000 (Bits 0-4 Intensity 32 steps 0-31 Default 31) Bits 5-6-7 (001 Red D32) (010 Green D64) (100 Blue D128) If NeoPixValue.6 = 1 then NeoPixValue = NeopixValue & Brightness 'Clear Colour bits & set Green Intensity else NeoPixValue = 0 'Turn LED Off endif NEOPIN = 1 ASM btfsc _NeoPixValue, 007h Bra doneg70 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg71 doneg70 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg71 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 006h Bra doneg60 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg61 doneg60 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg61 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 005h Bra doneg50 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg51 doneg50 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg51 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 004h Bra doneg40 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg41 doneg40 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg41 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 003h Bra doneg30 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg31 doneg30 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg31 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 002h Bra doneg20 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg21 doneg20 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg21 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 001h Bra doneg10 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg11 doneg10 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg11 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 000h Bra doneg00 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneg01 doneg00 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneg01 endasm NeoPixValue = NeoLed(NeoPixel) 'Second, the Red array 'Colours %000 10000 (Bits 0-4 Intensity 32 steps 0-31 Default 31) Bits 5-6-7 (001 Red D32) (010 Green D64) (100 Blue D128) If NeoPixValue.5 = 1 then NeoPixValue = NeoPixValue & Brightness 'Clear Colour bits & set Red Intensity else NeoPixValue = 0 'Turn LED Off endif NEOPIN = 1 ASM btfsc _NeoPixValue, 007h Bra doneb70 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb71 doneb70 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb71 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 006h Bra doneb60 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb61 doneb60 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb61 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 005h Bra doneb50 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb51 doneb50 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb51 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 004h Bra doneb40 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb41 doneb40 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb41 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 003h Bra doneb30 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb31 doneb30 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb31 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 002h Bra doneb20 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb21 doneb20 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb21 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 001h Bra doneb10 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb11 doneb10 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb11 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 000h Bra doneb00 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doneb01 doneb00 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doneb01 endasm NeoPixValue = NeoLed(NeoPixel) 'Lastly, the Blue array 'Colours %000 10000 (Bits 0-4 Intensity 32 steps 0-31 Default 31) Bits 5-6-7 (001 Red D32) (010 Green D64) (100 Blue D128) If NeoPixValue.7 = 1 then NeoPixValue = NeoPixValue & Brightness 'Clear Colour bits & set Blue Intensity else NeoPixValue = 0 'Turn LED Off endif NEOPIN = 1 ASM btfsc _NeoPixValue, 007h Bra doner70 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner71 doner70 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner71 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 006h Bra doner60 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner61 doner60 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner61 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 005h Bra doner50 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner51 doner50 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner51 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 004h Bra doner40 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner41 doner40 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM ; Bcf LATA,3 NOP NOP NOP NOP NOP NOP doner41 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 003h Bra doner30 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner31 doner30 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner31 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 002h Bra doner20 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner21 doner20 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner21 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 001h Bra doner10 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner11 doner10 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner11 ENDASM NEOPIN = 1 ASM btfsc _NeoPixValue, 000h Bra doner00 NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP NOP NOP NOP bra doner01 doner00 NOP NOP NOP NOP NOP NOP NOP ENDASM NEOPIN = 0 ASM NOP NOP NOP NOP NOP NOP doner01 endasm POINTER = POINTER - 1 'next pixel in the string IF POINTER.15 = 0 THEN DOGREEN' < NEO_NUM THEN DOGREEN return 'get back to main program.........
