Conway's Game Of Life
Results 1 to 40 of 46
    Feb 2007
    Default Conway's Game Of Life
    hello
    after seeing a few youtube videos on 'Conway's game of life' id like to have a go at building one on a 8x8 led matrix to start with, then maybe something bigger later.
    http://en.wikipedia.org/wiki/Conway's_Game_of_Life
    im just looking for some advice on how to check each of the cell's neighbours are alive or dead without writing a shed load of IF/THEN statments for each cell (on a 8x8 led matrix there would be 64 cells with upto 8 neighbours for each cell)
    If each LED is represented in a Bit Array, numbered from 0-63, from 0 at top left to 63 at bottom right, then, for any given LED 'x', it's neighbours are simply x-9, x-8, x-7, x-1, x+1, X+7, x+8 and x+9. The same routine can then be used on any cell in the array. Some extra code will have to account for display edges otherwise the patterns will 'wrap' out of one side of the screen and re-enter from the other... but then again that then will look like an interesting 'perpetual' colony!
    Feb 2007
    Thanks for your reply, this is roughly what i had in mind.
    so far i have come up with this bit of untryed code,
    from the grid below if cell (x) 31 is alive, and you wish to check its neighbours: x-9, x-8, x-7, x-1, x+1, X+7, x+8 and x+9
    you will end up checking 22, 23, 24,30,32,38,39,40
    which almost works for wrapping around except 40 is too far away.
    '0 8 16 24 32 40 48 56
    '1 9 17 25 33 41 49 57
    '2 10 18 26 34 42 50 58
    '3 11 19 27 35 43 51 59
    '4 12 20 28 36 44 52 60
    '5 13 21 29 37 45 53 61
    '6 14 22 30 38 46 54 62
    '7 15 23 31 39 47 55 63
    led var bit [64]
    counter var byte
    population var byte ' <<number of neighbours
    FOR counter = 0 TO 63
    population = 0
    IF led [counter-1] = 1 AND counter > 0 THEN
    population = population + 1
    IF led [counter+1] = 1 AND counter < 63 THEN
    IF counter > 7 THEN
    IF led [counter-8] = 1 THEN
    IF led [counter-9] = 1 THEN
    IF led [counter-7] = 1 THEN
    IF counter < 56 THEN
    IF led [counter+8] = 1 THEN
    IF led [counter+9] = 1 THEN
    IF led [counter+7] = 1 THEN
    IF led [counter] = 1 THEN
    IF population > 3 OR population < 2 THEN
    led [counter] = 0
    IF led [counter] = 0 THEN
    IF population = 3 THEN
    led [counter] = 1
    NEXT
    Well, 40 could be valid because (like for example the old Atari Asteroids game) you can wrap vertically as well as horizontally... if an Asteroid went off the top, it appeared at the bottom, and likewise when it went off one side, then it appeared on the other.
    Feb 2007
    have come up with this:
    i ended up allowing it to wrap vertically only which does keep the sequence of life going a bit longer..
    I think you'll need to create 2 arrays.
    One for the current generation, and one for the Next generation.
    The way it is now, you scan across each location and determine whether it's alive or dead and immediately change it's state.
    Then when you check the next location, it's making a decision based on the bit you just changed, which can't be considered until the next generation.
    As you scan 1 generation, place the results in a holding array. Once the entire board has been scanned for a single generation, update the LED's, and use that array as the "current generation", or copy it back to the first array.
    hth,
    Default Re: Conway's Game Of Life
    i had a bit of a "google" for stagnant life pattern detection . the answer was obvious CRC
    i resurrected my old code , added crc16 stored the last 8 crc's in a ring buffer. i then go on to check every new generation's
    crc for existence in the buffer, more than two counts and i call it a repeat and begin a new pattern
    works like a charm.
    The array transform routine, as posted above executes in 4.66ms on my test hardware (18F46K42 @64MHz).
    It's a small improvement but I managed to reduce that to 4.28ms by changing it into two FOR/NEXT loops, one for odd, one for even rows.
        FOR Col = 0 To 30 Step 2
            InPtr = (TempW + Col)
            led[InPtr] = lednew[InPtr]
            OutPtr = InPtr
            IF led[InPtr] > 0 THEN
               NeoLed(OutPtr) = Led[InPtr]
               alive = alive + 1
               dead = dead + InPtr
                NeoLED(OutPtr) = 0
        NEXT
        FOR Col = 1 To 31 Step 2    ' Odd rows
            OutPtr = (TempW) + (31-Col)   'Reversed order
               alive = alive + 1
               dead = dead + InPtr
               NeoLED(OutPtr) = 0
        NEXT
    I must point out though that I don't have the arrays populated with anything so their values are always zero which obviously will have an effect.
    Could I have a look at your Life CRC16 code please Richard?
    this is my ccitt16 crc code , i feed every byte in the cell array into it and store result in ring buffer after first testing to see if the new crc exists more than once in the buffer buffer, if its there more than once [or twice if you like] thats it game over.
    this is a ccit 16 crc routine
    crc var word
    crc_in var byte
    j var byte
    to use   set crc  to $ffff
    then set crc_in to each value to be crc'ed
    and gosub crc16
    when finished crc hold the crc value
    don't forget to reset crc to $ffff for next time
    crc16:
          crc= crc ^  crc_in
          for j=0 TO 7
             if (crc&1)  THEN
               crc= ((crc>>1) ^ $a001 )   ;
               crc= crc>>1;
          NEXT
    Default 256 Led Matrix running on 12F1840 Pic.
    As video.
    Colour 'Life' on tiny 12F1840.
    my first venture into youtube
    life on pic18f26k22@64mhz on 32x64 red,green p10 led panel , with word seeds
    Just amazing!
    Although I never fully understood that "game" your work looks impressive, especially on this P10 display in wide format.
    Nice job that video on YouTube also!
    Very nice Richard. What LED's are those?
    Did my thread resurrection encourage you.. LOL
    Can we have a look at your 2048 led code? In particular the word seeds....
    Thanks and very cool.
  1. programming jumping game
    By bokken in forum mel PIC BASIC Pro
    Last Post: - 17th February 2012, 06:40
  2. Simon Game
    By flotulopex in forum Code Examples
    Last Post: - 4th November 2010, 06:25
  3. EEPROM life expectancy?
    By muddy0409 in forum General
    Last Post: - 1st May 2007, 12:44
  4. home brew game console W interface
    By PICMAN in forum General
    Last Post: - 15th March 2005, 22:25
  5. Game port to USB adaptor
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 24th September 2004, 03:16
