Pic to Pic communication
Results 1 to 12 of 12
Threaded View
  1. #10
    Your best bet will be to use an external OSC.
    To clarify this statement, your choice of a crystal and caps, a 3 pin resonator, or an external oscillator. Or you might try a lower Baud rate with the internal to see if that works, it really depends how much and which way the intosc is off frequency. A big ALSO . . . make sure the analog stuff is turned off on those ports you are using . . . try these:
    cmcon0 = 7
    adcon0 = 0
    PICs are funny, they default to almost everything turned on, whereas you would think it would default everything off.
  1. 2 PIC, serial communication
    By lightgreen in forum Serial
    Last Post: - 21st November 2009, 16:20
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 21:02
  3. PIC 2 PIC communication
    By Mario in forum Forum Requests
    Last Post: - 28th April 2006, 02:56
  4. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
  5. Pic to Pic communication?
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 11th April 2004, 20:41
