Enhancement of FAQs ??
Results 1 to 3 of 3
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Enhancement of FAQs ??
    I'm now two years into PBP programming and still have a clear memory of early starting difficulties.
    I'd like to suggest a series of 'Check lists' for various activities. Proposals to get on the lists would be controlled by some of our very experienced contributors.
    As an example, one of the checklists could be
    EEPROM and I2C. Have you:
    1. Used pull-ups on the SCL and SDA pins. 4.7k, not 10k?
    2. Got the control byte correct, '1010' and then....
    3. ...either Chip Select or Page/Bank Address.
    4. The Control byte is 8 bits and PBP takes care of the R/W bit
    5. Got the Address BYTE or WORD correct, one or the other, not either!
    6. Not used a constant for the Address BYTE or WORD.
    7. Note that Pins1,2,3 are A0,A1,A2 and chip select is the reverse A2/A1/A0.
    8. And so on....
    After a few months, the lists should contain all common errors.
    Regards Bill Legge
    Sep 2007
    USA, CA
    While that is a great idea, only those who don't need it will read it. It seems that newbies are always in too big of a hurry to read the existing help...
    Default newbies
    There is a possible software solution to that, newbies profiles could be done in such a way as to direct them to FAQ area at login, for say the first 10 or so session logins.
  1. Where are all the FAQ's?
    By boroko in forum FAQ - Frequently Asked Questions
    Last Post: - 14th March 2008, 06:56
  2. Default thread age for FAQ's
    By JohnH in forum Forum Requests
    Last Post: - 8th October 2007, 03:11
