SPo3 and I2C
Results 1 to 8 of 8
Thread: SPo3 and I2C
    fatboylives's Avatar
    fatboylives Guest
    Default SPo3 and I2C
    Hi all.
    I need what might be some basic help with some I2C code.
    I have a SP03 module and the I2C specs for that are on http://www.robot-electronics.co.uk/htm/Sp03doc.shtml
    I am using a 16f877 with 20 mhz crystal. Basically for now I need to read the command status? Can anyone offer a suggestion? Also are the pins I have selected to use for Data and Clock ok on the 877 or should I be using specific pins? Do they need pull up resistors? I have tried different varioations of code and can't get a response....
    My code
    DEFINE OSC 20
    define i2c_slow 1' Tried this as a test
    Wdog Var Portb.7
    DPIN var PORTB.6 ' I2C data pin
    CPIN var PORTB.5 ' I2C clock pin
    talk var portd.2 ' Indicate still busy
    NOP CON 0
    B1 var byte
    High talk 'Unit talks on power up. So indicate
    loop:
    Toggle wdog
    pause 200
    I2CREAD DPIN,CPIN,$C4,[B1] 'Read if still talking
    if b1 > 0 then goto loop
    low talk
    goto loop
    Your selected pins are O.K. Yes you need external Pull-ups ... 4.7K is a common used value.
    fatboylives Guest
    Thanks for the help so far. I will give it a go.
    Do I also need the define i2c_slow 1? I read the manual as it is needed if speed is over 4 megs so I take it as yes?
    Hi fatboylives, They say they test it over 1MHZ I2C clock so you don't need the define. In PBP I2c SLOW is 100KHZ when not 400KHZ
    fatboylives Guest
    What happened to your previous post. When I logged in to read your reply re the Define part, I went back to read your earlier post and grab the code and there is none there? I can only see the
    part. The code you provided has vanished....
    Does this happen or am I just over tired?
    Nop, i remove the code myself. I was really not sure of the way we have to talk to this module. Info are not so clear... maybe i'm a pure idiot and over-tired myself too.
    I see different way to access. So i bet we can read from control register like
    ModuleAddress = $C5
    CommandRegister = 0
    I2CREAD DPIN,CPIN,ModuleAddress,CommandRegister,[B1]
    or
    ModuleAddress = $C4
    CommandRegister = 0
    I2CWRITE DPIN,CPIN,ModuleAddress,[CommandRegister]
    ModuleAddress = $C5
    I2CREAD DPIN,CPIN,ModuleAddress,[b1]
    i don't know :-(
    fatboylives Guest
    Is there any reason your example shows moduleaddress as $C4 on the write and $C5 on the read? Shouldn't they be the same.
    I might have to use serial instead of I2C if I cannot get it to work...
    Currently I get various values returned and nothi9ng makes sense....... Not unusual for me :-)
