Hex converting
Results 1 to 10 of 10
Thread: Hex converting
    Talking
    This is how I hot it working, you were right about the A being 65
    HEXConvert:
    IF DATAA = 65 THEN
    	DATAA = 10
    IF DATAA = 66 THEN
    	DATAA = 11
    IF DATAA = 67 THEN
    	DATAA = 12
    IF DATAA = 68 THEN
    	DATAA = 13
    IF DATAA = 69 THEN
    	DATAA = 14
    IF DATAA = 70 THEN
    	DATAA = 15
    	DATAA = DATAA - 48
    Hmm, some people still like spaggeti much more!
    Hope at least there is a good salsa with it...
    Apr 2009
    Pittsburgh, PA
    Default Better code
    If you're sure your data really just consists of the digits and letters A through F, use this instead. Including comments will help when you come back to it later too.
    ' This works because 0 - 9 have decimal codes 48 - 57 and A - F have
    ' decimal codes 65 - 70 in ASCII
    HEXConvert:
    IF DATAA >= 65 THEN
    	DATAA = DATAA - 55 ' 65 - 55 = 10, 66 - 55 = 11 etc
    	DATAA = DATAA - 48 ' 48 - 48 = 0, 49 - 48 = 2 etc
    http://www.asciitable.com/.
    Thank you tried the new code and works like a charm
    May 2008
    Italy
    eg. 07D9 is what i am getting it must become a year number 2009
    An algoritm to convert Hex to Dec is as follows:
    Hex 07D9 = 9x16^0 + 13x16^1 + 7x16^2 + 0x16^3 = Dec 2009
    I don't see how you achieve the convertion with your system!
    Al.
    Apr 2009
    Pittsburgh, PA
    Quote Originally Posted by aratti View Post
    Al.
    I'm sure he's using the partial algorithm he gave to get the 13 from the D for example and then plugging it into another equation like yours.
    Apr 2009
    Pittsburgh, PA
    Talking
    Quote Originally Posted by ukemigrant View Post
    HEXConvert:
    IF DATAA >= 65 THEN
    Of course 49 - 48 <> 2 . Luckily it was in the comments but still...
  1. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  2. Converting Dec word to Hex string
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 05:44
  3. Need help converting to ASCII Hex format
    Last Post: - 26th August 2007, 19:14
  4. Converting ASCII to HEX
    Last Post: - 27th September 2006, 10:21
  5. Converting Bytes from hex to Dec
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 19:44
