<font color=red>INT_Handler RX_INT, _Get_char,  PBP,  yes</font color>
<font color=blue>@ INT_ENABLE RX_INT ; enable UART RX interrupt
</font color>
 The code in red is the receive interrupt, open DT-INTS and READ the options available, in amongst those are RB and INT choices, add them the way Darrel wrote them, into your interrupt macro, then enable them as done in Blue.
Example:
INT_HANDLER INT_INT, _MyNewLabel, PBP,yes
@ INT_ENABLE INT_INT ;enable External Interrupts
 Here is your selection snipped from DT-Ints14
	  #define INT_INT   INTCON,INTF     ;-- INT External Interrupt
  #define RBC_INT   INTCON,RBIF     ;-- RB Port Change Interrupt
  #define TMR0_INT  INTCON,T0IF     ;-- TMR0 Overflow Interrupt 16F
  #define TMR1_INT  PIR1,TMR1IF     ;-- TMR1 Overflow Interrupt
  #define TMR2_INT  PIR1,TMR2IF     ;-- TMR2 to PR2 Match Interrupt
  #define TX_INT    PIR1,TXIF       ;-- USART Transmit Interrupt
  #define RX_INT    PIR1,RCIF       ;-- USART Receive Interrupt
  #define CMP_INT   PIR2,CMIF       ;-- Comparator Interrupt
  #define EE_INT    PIR2,EEIF       ;-- EEPROM/FLASH Write Operation Interrupt
  #define BUS_INT   PIR2,BCLIF      ;-- Bus Collision Interrupt
  #define PSP_INT   PIR1,PSPIF      ;-- Parallel Slave Port Read/Write Interrupt
  #define AD_INT    PIR1,ADIF       ;-- A/D Converter Interrupt
  #define SSP_INT   PIR1,SSPIF      ;-- Master Synchronous Serial Port Interrupt
  #define CCP1_INT  PIR1,CCP1IF     ;-- CCP1 Interrupt
  #define CCP2_INT  PIR2,CCP2IF     ;-- CCP2 Interrupt
 INT_Handler RX_INT, _Get_char,  PBP,  yes  tells the PIC<b> WHICH</b> interrupt to use and <b>WHICH</b> label to jump to.
