garbled text on LCD
Results 1 to 5 of 5
    mslaney's Avatar
    mslaney Guest
    Default garbled text on LCD
    Hi there,
    I'm getting garbled text on my Hitachi based LCD attached to a 16F876. Most of the letters are legible but sometimes it skips a letter or misprints multiple letters. I've tried three seperate displays with the same results.
    Here's my code.
    'Chip config
    trisa = %00000000
    trisb = %00000000
    'General Defines
    define LOADER_USED 1
    define OSC 20
    'LCD Defines Pins / port for LCD data I/O
    define LCD_DREG PORTB
    define LCD_DBIT 4
    define LCD_RSREG PORTB
    define LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 0
    define LCD_BITS 4
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    START:
    pause 600
    lcdout $fe,1
    lcdout $fe,2
    porta = %00000001
    lcdout "hello world"
    porta = %00000000
    goto start
    Try remove those
    else, try to play with LCD_COMMANDUS and LCD_DATAUS value
    Also try to print to LCD in a one task
    LCDOUT $FE,1,"Hello world !"
    Be sure you program your PIC with HS oscillator setting.
    mslaney's Avatar
    mslaney Guest
    RIGHT!
    It looked like a 'baud' problem so then I guess speed and process time would be similar!!
    Thanks again...and again...and again...
    mslaney's Avatar
    mslaney Guest
    That worked great.
    It seems like an awful lot of typing the defines though. Could I somehow make an include file that has all of that in it?
    Yes you can. But i'll prefer to do some program header and use them after. In my case, i'd do program header for each PIC i use with the configuration fuses and blah blah blah. You can do some with LCD define too and reuse them after. I feel safer to see all the code in front of me. BUT if you still want to do some INCLUDE files, create a new file.bas and then place INCLUDE "lcdstuff.bas" at the top of your code.
  1. Replies: 2
    Last Post: - 5th November 2009, 18:07
    Last Post: - 8th August 2009, 20:54
  3. LCD issue with EasyPIC5
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th June 2008, 10:17
  5. LCD will not start
