16F877A equal with more memory
Results 1 to 8 of 8
    Mar 2006
    China
    Default more
    18F4620 or 18F46K20 (no eeprom)
    18F452 is also pin compatible but a bit old.
    Sep 2007
    USA, CA
    Quote Originally Posted by Jumper View Post
    Worse, it's at its End of Life, according to microchip.
    Mar 2006
    China
    Default End of life
    Components don't die.. they slowly fade away. I just mentioned it because there are still millions of them out there.
    With the 4520 being cheaper and better, there is no reason to continue with the 452.
    The 18F46K20 DOES have 1024 bytes of EEPROM...
    What you might be thinking of is the 18F46J11 series... it may not have EEPROM, but you obviously missed what it DOES have instead (which obsoletes the EEPROM completely)... and with an integral RTC as well, it's a winner for a lot of applications... shame it's not supported by PICBasic yet...
    But be carefull, it is a 3.6 Volts (max) device!!! NOT a 5 Volt!
  1. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 20:27
  2. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  3. Replies: 4
    Last Post: - 2nd March 2007, 06:12
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 18:52
