How to disable CVREF on PIC16F690?
Results 1 to 4 of 4
    CV1REN, CV2REN and VP6EN bits of the VRCON Register.
    See 8.10.1 and Register Table 8-5.
    Mar 2009
    Colorado
    Default Same question for T0CKI?
    Thanks so much Melanie. As much as I searched the data sheet I somehow missed this.
    I have a similar question regarding T0CKI. Data sheet sheet says to minimize power during SLEEP the T0CKI pin should be at Vdd or Vss. Since T0CKI is multiplexed win pin RA2, I have been searching datasheet looking at how to select T0CKI and only register I see it referenced in is OPTION_REG bits 4 and 5. Don't see T0CKI mentioned in any other registers.
    If I set bits 4 and 5 to 1 in OPTION_REG does that select T0CKI on pin RA2??? If that is the way to make the selection, I presume I would then just make the PBASIC statement PortA.2 = 0 to set it to Vdd for minimum power consumption????
    Tricky... simply setting the pin to Output could clash with whatever external circuitry you're using to drive the Clock. Obviously what Microchip wants you to do is not toggle the pin, that will naturally stop the PICs internals from doing their thing. If you have a pull-up on that pin, pulling it to 0v will start drawing current... a little more thought is needed as to what how and where before a decision is made on this one.
  1. PIC16F690 code help please
    By hysteria92 in forum mel PIC BASIC
    Last Post: - 24th February 2010, 17:17
  2. Replies: 1
    Last Post: - 19th February 2009, 14:35
  3. Replies: 0
    Last Post: - 13th February 2009, 04:34
  4. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:05
  5. Enable and Disable in Interrupts
    By stevecrunch in forum mel PIC BASIC Pro
    Last Post: - 30th October 2007, 02:10
