Pic12f683 Cmcon0 = 7
Results 1 to 26 of 26
    Jun 2005
    Default Pic12f683 Cmcon0 = 7
    Hi! I just purchased some PIC12F683s and am having some problems. The simple program I wrote takes a 0 to 5V analog voltage from a 5k potentiometer and this adjusts HPWM. I have 0.1uF caps in place from VDD to VSS and another on the pot's wiper. At the moment, the HPWM drives an LED. Ultimately it will feed a mosfet that will control a small toy motor.
    Compiler - PisBasic Pro 2.47
    Using MicroCode Studio
    Pic - PIC12F683
    I get a syntax error on the line "CMCON0 = 7" which disables the comparators. Yes, I tried "0" and "O" and just "CMCON". As well, I am getting irratic behavoir from the HPWM where as I adjust the pot, the duty cycle jumps around irraticaly. I used an oscilloscope to verify the behavior.
    Any advice would be appreicated. The program is below;
    INTCON = %10001000 ‘internal oscillator
    OSCCON = %01110000 ‘ 8mHz
    CMCON0 = 7 'Comparators off
    GPIO = %00000000 'outputs low
    TRISIO = %00010000 'GP3 as input
    ANSEL = %00111000 'AN3 analog
    'Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    Define CCP1_REG GPIO 'PWM Output on gpio
    Define CCP1_BIT 2 'Bit 2
    ‘ Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    ADCIN 3, Posit ' Read channel AN3 to Posit
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    Jan 2006
    Istanbul
    Quote Originally Posted by penelopepug View Post
    ...and another on the pot's wiper.
    Remove the cap.
    ...I get a syntax error on the line "CMCON0 = 7" which disables the comparators. Yes, I tried "0" and "O" and just "CMCON".
    Select the correct PIC model from the drop down menu in MicroCode Studio.
    INTCON = %10001000 'internal oscillator
    OSCCON = %01110000 '8mHz
    Add, DEFINE OSC 8.
    Not sure why you used these?
    Pic - PIC12F683
    ‘ Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    Hello,
    Without checking to see if this code works, and without reading for understanding, I did compile as presented below and it compiles. I found 3 things which prevented it from compiling. You used ` instead of ' on some of your comments and you defined
    which are already defined in the 12f683.bas file. I just commented them out.
    HTH
    JS
    Oh, BTW, a scratchy pot can do wild things when used here too, and Sayzer will never steer you wrong.
    OSCCON = %01110000 ' 8mHz
    'Define CCP1_REG GPIO 'PWM Output on gpio
    'Define CCP1_BIT 2 'Bit 2
    ' Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    Jun 2005
    Default PIC12F683 Problems
    Thanks for looking at this for me. I should have realized that the "bas" file sets up the HWPM for me. However I am not sure this is the source of the problem. I did look at the output of the pot and it is perfectly clean with and without the capacitor. It seems to be related to the anolog sampling or calculation (I think). As for the compiling issue, I did select the correct PIC but no matter what I do the CMCON0 shows up as a syntax error for me. I ended up commenting it out and moving the analog over to a differing port so as to not have to worry about the error.
    The problem probably stems from the fact that you are most likely updating the duty cycle in the middle of performing a cycle. The datasheets talk about that sort of thing. What happens if you just run the program in a loop that doesn't change the duty cycle?
    As far as the A/D output, are you sure the A/D output (the number returned by the ADCIN command) is smooth in the first place? Maybe a 10ms pause isn't enough (not likely), maybe too much. Add in a bit of code to average out the duty cycle itself, software averaging of some sort, move the duty cycle around 'slower'...see what happens.
    And as far as CMCON goes, just POKE the value into the appropriate register and see what happens.
    Jun 2005
    Thanks skimask. You've given me some things to try. I'll post my findings assuming I resolve the problems. Thanks again.
    Jan 2006
    Istanbul
    ....You used ` instead of ' on some of your comments.
    penelopepug,
    May be you missed what Joe talks about.
    Pay attention to these characters;
    as you know, they are not the same characters and will give you syntax errors.
    Jun 2005
    Quote Originally Posted by sayzer View Post
    penelopepug,
    Hi Sayzer. I had retyped that line and copied and pasted it a few times thinking something hidden was the problem. However I'll take a close look at that, hopefully tonight. Thanks again.
    Hello,
    Edited.
    TRISIO = %00010000 'GP4 as input
    ' Variables
    Posit var Word
    Speed var byte
    Pause 100
    Scan:
    Speed = Posit/4
    HPWM 1,Speed,1000
    Pause 10
    Goto Scan
    OK, I'm still trying to understand this and use code, so I thought that I would revive this thread.
    Above, the code has "ANSEL = %00111000 'AN3 analog" To me it looks like AN4 and 5 are also made analog. Is this needed? if it is not needed, I should be able to use:
    ANSEL = %00001000  ' AN3 analog
    ~ Dave
    Quote Originally Posted by StoneColdFuzzy View Post
    ~ Dave
    For the 12F683 there is no AN4 and AN5, those bits control the data conversion clock. see the Data sheet page 33.
    OK, yes, I see that now. Are they to be set to 1 for this application? Where may I find more information in layman's terms to help me understand what that is?
    ~ Dave
    Nov 2008
    This may help you a bit. I've been playing with the 12F683.
    @	__CONFIG _INTOSCIO & _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _BOD_OFF & _CP_OFF & _MCLRE_ON & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF
    DEFINE OSC 8           ' Internal 8MHz
    DEFINE ADC_BITS 8      ' 8-bit resolution
    DEFINE ADC_CLOCK 2     ' Set clock source to Frc/32
    DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
    ADCON0 = %00000001		'ADC enabled and right justified
    ANSEL = %00001000		'GPIO.0 and GPIO.1 analog input
    INTCON = 0				'INTERRUPTS off
    OSCCON = %01110000		'8 Mhz
    TRISIO = %111011		'GPIO2 output
    GPIO = %00010000 		' All outputs = 0 on boot
    astouffer, thank you.
    What's wrong when I can compile multiplication but not division? I get this error "macro div?ctb not found in macro file."
    This compiles OK:
    width = 510 * mon
    This will not compile:
    width = 510 / mon
    ~ Dave
    I've been playing with this code to change HPWM depending on a monitored voltage. The original code at the top of this thread works, but it's erratic.
    I've changed things around a bit to fit my needs and it runs a little bit better, but it's still erratic, probably due to refreshing the duty cycle all of the time. I'm looking for suggestions to make this run a little more smooth. Any suggestions?
    ~ Dave
    Mon var Word
    Width var byte
    Pause 100
        ADCIN 3, mon ' Read channel AN3 to Mon
        width = mon*1
        if width <= 2 then OneP
        if width > 2 then twoP
    OneP:
        hpwm 1,255,2000
    TwoP:
        hpwm 1,32,2000
    ~ Dave
    Mon var Word
    Width var byte
    Pause 100
        width = mon*1
    OneP:
        hpwm 1,255,2000
    TwoP:
        hpwm 1,32,2000
    Anyone?
    ~ Dave
    Dave - What is your definition of 'erratic'?
    width = mon*1
    Oh... Can you tell me what is the point of the *1 part of this line?
    Basically your program states that if mon is >2 then your HPWM will be at around 12.5% otherwise it will be solid ON. There's not much else that happens... or at least it would do if you remembered a GOTO MAIN after the last IF statement!!! Because as it is, your code is slamming straight into the OneP section.
    You could rewrite your code as...
        width = mon
        if width > 2 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
    I'm also assuming you've set TRISIO and such properly.
    width = mon*1
        width = mon
        if width > 2 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
    Melanie,
    Thank you for replying.
    Initially, I couldn't get the code to compile without width=mon*1. I've sice removed the *1 and it compiles OK now. No idea why.
    Erratic = while it's executing hpwm 1,255,2000 when "width is less than 2" with either version of code, it cycles randomly back and forth to 1,32,2000. While "width is greater than 2" the output is stable.
    I'm going to try a while wend in there.
    ~ Dave
    Here's what I'm using since your reply:
    ' Variables
    Mon var Word
    Width var byte
    Pause 100
        width = mon
        if width > 2 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
    OK, the penny's dropped...
    mon = 16 bits, whilst width = 8 bits... you can't put a quart into a pint pot...
    try...
    width = mon/4
    In case you're wondering why /4 instead of /8... that's because your ADC reading is 10 bits. So why not read 8-bit ADC to start with?
    try...
    width = mon/4
    Because I'm such a noob that I have no idea how to do that. Now I'm really confused.
    So with this change, when the IC reads less than 2 volts on "mon" it should execute hpwm 1,255,2000; more than 2 volts and it should execute 1,32,2000?
    ~ Dave
    Looks like we have a lot to learn here...
    No, it WON'T be two volts....
    The ADC returns a number between zero and 1023 (because you are in 10-bit mode), where zero equals 0v on the ADC, and 1023 equals full-scale 5v on the ADC. Each click on the ADC scale represents 1/1023 ie a FRACTIONAL part of 5v.
    So if 5v = 1023, then 2v will be two fifths of 1023 (namely 409).
    So, if you want the trip point to be 2v and with a 10-bit ADC, your code should be...
        if mon > 409 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
        if mon > 409 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
    Wow, it's no wonder I was frustrated enough to chew the lips off of a carp!
    OK, where is it that I look up the ins and outs of 8 bit, 10 bit and such? I'd love to find a PBP book for Dummies or something like it.
    Thanks again Melanie!
    ~ Dave
    try...
    width = mon/4
    So, if I would have used Define ADC_BITS 8, I would have been OK?
    ~ Dave
    Well, in that case with 8 bit ADC, variable mon should be a BYTE rather than a WORD.
    Your ADC range for 0-5v is an ADC reading of 0-255 where 255=5v.
    So 2 volts will be 2/5ths of 255 namely 102...
    So the IF statement then becomes IF mon > 102 THEN...
    The decision to use 8-bit or 10-bit ADC is simply a matter of precision, and you chose whether you need steps of 1/255 or 1/1024 for the ADC span that you are using.
    Melanie,
    1/255 is fine.
    Where can I go to learn the basics of using AD conversions? It's obvious that I have no clue.
    Thanks again for the help.
    ~ Dave
    Posts #20 and #23 of this thread... and you're almost there... it's real simple... add to that the ADCIN section of your PBP Manual and the ADC Section of your chosen PICs Datasheet.
    Lesson 1.
    Get a PIC with ADC Input capability and enough pins to drive an LCD Display. Hook it up so you can send messages to your LCD. Put a POT (10K or 5K) across your 5v supply with the wiper to the PIC ADC pin. Write a small program to display what the ADC value is when reading 8-bit. Wind the POT up and down a few times to see digits change...
    Lesson 2.
    Repeat above with 10-bit ADC input.
    You're an expert!
    Melanie,
    OK, I contacted my supplier rep and he's sampling me some LCD screens and driver ICs. He gasped and said "Wow, you're finally going digital!"
    I also went a step further and ordered the book, Programming PIC Microcontrollers with PICBASIC. Something that I should have done a long time ago.
    Thanks again!
    ~ Dave
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  3. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  4. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 19:16
  5. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 17:17
