Installing PICBASIC PRO
Results 1 to 4 of 4
    Jun 2009
    Utica, NY
    Red face Installing PICBASIC PRO
    I'm a newbe and have limited computor background and am having problems getting PBP working with MP LABS 8.15. Computer is running Win. XP. I have installed MPLAB 8.15, Installed PBP 2.5 from the disk, and extracted the MPLAB PLUGINS to the C\PBP folder. The following statement has been added to the end of PATH per the instructions.
    "%SystemRoot\System32\C:PBP;C:\Program Files\Microchip\MPASM Suite"
    The PBP Compiler has been set in the 'Language Tool Locations'.
    I have a very simple program using a 16F690 and the "BLINK" sample code.
    Compiling using F10 always results in the same error message: "ERROR: Unable to execute mpasmwin". I have been working on this for several days and have been making zero progress. The programs have been removed and reinstalled multiple times and multiple restarts after changes; but always the same result. The forum files have been searched using "Unable to execute mpasmwin" as the search string which brought up nine paths which I followed and tried some of the fixes. One fix using a Basic window I did not understand so did not try it.
    I did have PBP Demo installed (downloaded from home site) and along with MPLABS 8.15 and it worked well being able to compile using F10 in MPLABS.
    I will appreciate any help this group can offer. I have a project to complete and am at a standstill until this issue is resolved.
    Sorry for the rambling. Rod
    Dec 2005
    So Cal and loving it
    Sorry, I have never used PiBasic with the MPLAB plugins so cant help you with that but I'm sure someone else will chime in with ideas.
    I would suggest that you download Microcode studio and give it a go (I love it). You can choose whether to use PM or MPASM as the assembler and it can interface to several programmers too.
    Good luck and welcome to the forum.
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    May 2009
    USA
    Check out this article:
    http://www.melabs.com/support/mplab.htm
    Why is the email address verification case sensitive?
    Jun 2009
    Utica, NY
    Default Installing PBP
    Hi GoldStar,
    Thanks for the reply. I have been using the MELabs install procedure as well as Chuck Hellebuyck's article in May 08 N&V. Rod
  1. Conversion from picbasic pro to hex for mplab
    By pr2don in forum Forum Requests
    Last Post: - 10th October 2010, 20:53
  2. PicBasic Pro Demo
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 20:10
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
