Instruction times
Results 1 to 3 of 3
Threaded View
  1. #3
    Some asm instructions takes 1, some other takes 2 instruction to execute, if you add conditionnal instruction then you mess up everything as they can use 1 OR 2 instructions, hence Code size is not a safe way to evaluate execution speed.
    What you want to use is a internal Timer, MPLAB stopwatch OR toggle a I/O then measure it with a scope.
    Look at the following, for simple code implementations. Note that you'll need to adjust those to suite 20MHz.
    http://www.picbasic.co.uk/forum/show...33&postcount=9
    http://www.picbasic.co.uk/forum/show...9&postcount=13
    For accuracy, you want to use internal timer instead of Pause/PauseUs. This also allow you to do something else in meantime.
    HTH
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Calling Subroutines Multiple Times
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 07:11
  3. instruction cycles for math operations
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 11:03
  4. code size using On Interrupt PBP instruction
    By eduardojx in forum mel PIC BASIC Pro
    Last Post: - 21st December 2005, 09:57
  5. instruction execution time
    By tjg in forum Code Examples
    Last Post: - 21st April 2004, 18:15
