'* Name : New_PWM.bas *
'* Author : Roddy Wayne *
'* Notice : Copyright (c) 2009 *
'* : All Rights Reserved *
'* Date : 05/09/2009 *
'* Version : 1.0 *
'* Notes: *
' Hi All,
'The problem I'm having is: The input to A2D 0, is somehow effecting
'the input to A2D 1. A2D 0 is reading a Pot's Position. A2D 1 is
'reading an analog voltage set up by an LM34 Temperature unit.
'The Temp unit works fine (A2D 1)until I increase the Pot's Position
'going into A2D 0. Doing this is causing the the Temperature to
'rise up to 33 degrees.
'Don't know what I've done wrong but, I'm sure there's something
'I've missed!
'I'd be greatful for any help!
'Thank You!
'Roddy
CLEAR ;always start with clear
DEFINE OSC 4 ;define oscillator speed
DEFINE ADC_BITS 8 ; Sets number of bits in result
DEFINE ADC_CLOCK 3 ; Sets clock source (3=rc)
DEFINE ADC_SAMPLEUS 400 ; Sets sampling time in uS
define DEBUG_REG PORTC
DEFINE DEBUG_BIT 6
define DEBUG_BAUD 2400
DEFINE DEBUG_MODE 0
DEFINE DEBUG_PACING 8000
Low PORTE.2 ;makes low for write only
TRISA = %00000111 ;sets porta 0, 1, & 2, as an inputs (A to D's)
TRISB = %00111111 ;sets bits 6 & 7 portb pins as outputs, 0 thru 5 as inputs
TRISC = %10111111 ;sets port c.6 for serial output, rest to inputs
TRISD = %00000011 ;sets PORTD 0,1, lines to inputs, rest to outputs
TRISE = %00000000 ;sets all PORTE lines to output
potpos var BYTE ;VAR BYTE for Pot Position
celltemp VAR BYTE ;VAR BYTE for Cell Temperature
A2D_V VAR BYTE ; Create A2D_V Value to store potpos result
A2D_V2 Var BYTE ;Create A2D_V2 Value to store cellamps result
ADCON1=%00000000 ;Sets the Analog to Digital control register
Start:
If portc.0 = 0 then portb.6 = 0 'If pin 15 is low, make pin 39 low
If Portc.0 = 1 then portb.6 = 1 'If pin 15 is high, make pin 39 high
'When Pin 39 goes high, this turns the
'pump on! I'm using a Darlington pair
'to do this (Part # TIP130) It also
'turns on the "Pump On" LED.
If portc.3 = 0 then portb.7 = 0 'If pin 18 is low, make pin 40 low
If portc.3 = 1 then portb.7 = 1 'If pin 18 is high, make pin 40 high
'When Pin 40 goes high, the "Low Tank
'Water" LED is turned on!
debug 1, 14 'Send curser home & Turn Backlight on
Pause 100 'Pause .1 second
HPWM 2, 127, 17500 'Output is a 17.5 Khz, 50% duty cycle (pin 16)
ADCON0=%11001101 'Sets up the AtoD Module to read Channel 1
ADCIN 1, A2D_V2 'Read channel 1 to A2D_V2 Value
celltemp= 1+(((300-70)*A2D_V2)/255*2)
DEBUG "Cell Temp = ", DEC3 celltemp," ", 223, 70," "
DEBUG "Cell Temp = ", BIN8 celltemp
Pause 200
ADCON0=%11000101 'Sets Up the AtoD Module to read channel 0
ADCIN 0, A2D_V ' Read channel 0 to A2D_V Value
potpos= 1+(((255-1)*a2d_v)/255)
Debug "Pot Position = ", DEC3 potpos," "
Pause 200
If (potpos <=%00001111)and(potpos <=%00011011) then percent_20 '15 to 27
Pause 200
If (potpos <=%00011100)and(potpos <=%00111111) then percent_40 '28 to 63
Pause 200
If (potpos <=%01000000)and(potpos <=%01011001) then percent_60 '64 to 89
Pause 200
If (potpos <=%01011010)and(potpos <=%01110011) then percent_80 '90 to 115
Pause 200
If (potpos <=%01110100)and(potpos <=%01111110) then percent_100 '116 to 126
If (potpos >=%01011110) Then percent_100
percent_20: 'Asking for 20% high PWM
HPWM 1, 51, 17500 'Output is a 17.5 Khz, 20% duty cycle (pin 17)
DEBUG "PWM = 20%High/80%Low"
Pause 100
GoTO start
percent_40: 'Asking for 40% high PWM
HPWM 1, 102, 17500 'Output is a 17.5 Khz, 40% duty cycle (pin 17)
DEBUG "PWM = 40%High/60%Low"
Pause 100
GoTO start
percent_60: 'Asking for 60% high PWM
HPWM 1, 153, 17500 'Output is a 17.5 Khz, 60% duty cycle (pin 17)
DEBUG "PWM = 60%High/40%Low"
Pause 100
GoTO start
percent_80: 'Asking for 80% high PWM
HPWM 1, 204, 17500 'Output is a 17.5 Khz, 80% duty cycle (pin 17)
DEBUG "PWM = 80%High/20%Low"
Pause 100
GoTO start
percent_100: 'Now at 100% on PWM
HPWM 1, 254, 17500 'Output is a 17.5 Khz, 100% duty cycle (pin 17)
DEBUG "PWM = 99%High/01%Low"
Pause 100
GoTO start
