How to reverse polarity on output pulse??
Results 1 to 4 of 4
    Mar 2009
    Colorado
    Cool How to reverse polarity on output pulse??
    I am using a 16F690 PIC to control a latching solenoid on a valve. The latching solenoid requires a pulse with positive polarity to open and another pulse of negative polarity to close. Generating the postive polarity pulse at the output pin of the 16F690 is no problem, but I am not grasping how to generate a negative polarity pulse at a pin output. Can anyone advise me or refer me to an explanation? Thanks!
    May 2008
    Italy
    If solenoid current is within pic capability (thing that I doubt) you can use two outputs pins to drive your solenoids. Reversing polarity means having pin 1 high and pin 2 low or pin 1 low and pin 2 high.
    If solenoid current is higer then you must use a mosfet Hbridge.
    Al.
    Default H-bridge
    Use a H-Bridge...(MCP1404 or TC4424 by example)
    ...take a look at http://www.robotroom.com/HBridge.html (you have to add some charge capacitors also)
    Lightbulb Hard or soft way ???
    Either way you do it ... it will use 2 output pins ...
    Or,or,or ... if you use some kind of twin monostable multivibrator on one output, like the ones used to extend or retract the cars radio antennas ... that we found some car generations ago !!!
  1. Synchronous pulses
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 18th October 2009, 16:32
  2. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  3. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  4. Replies: 3
    Last Post: - 13th September 2008, 17:40
  5. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
