A/D problems
Results 1 to 2 of 2
Thread: A/D problems
    Apr 2009
    Angry A/D problems
    '* Name : New_PWM.bas *
    '* Author : Roddy Wayne *
    '* Notice : Copyright (c) 2009 *
    '* : All Rights Reserved *
    '* Date : 05/09/2009 *
    '* Version : 1.0 *
    '* Notes: *
    ' Hi All,
    'The problem I'm having is: The input to A2D 0, is somehow effecting
    'the input to A2D 1. A2D 0 is reading a Pot's Position. A2D 1 is
    'reading an analog voltage set up by an LM34 Temperature unit.
    'The Temp unit works fine (A2D 1)until I increase the Pot's Position
    'going into A2D 0. Doing this is causing the the Temperature to
    'rise up to 33 degrees.
    'Don't know what I've done wrong but, I'm sure there's something
    'I've missed!
    'I'd be greatful for any help!
    'Thank You!
    'Roddy
    CLEAR ;always start with clear
    DEFINE OSC 4 ;define oscillator speed
    DEFINE ADC_BITS 8 ; Sets number of bits in result
    DEFINE ADC_CLOCK 3 ; Sets clock source (3=rc)
    DEFINE ADC_SAMPLEUS 400 ; Sets sampling time in uS
    define DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    define DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 8000
    Low PORTE.2 ;makes low for write only
    TRISA = %00000111 ;sets porta 0, 1, & 2, as an inputs (A to D's)
    TRISB = %00111111 ;sets bits 6 & 7 portb pins as outputs, 0 thru 5 as inputs
    TRISC = %10111111 ;sets port c.6 for serial output, rest to inputs
    TRISD = %00000011 ;sets PORTD 0,1, lines to inputs, rest to outputs
    TRISE = %00000000 ;sets all PORTE lines to output
    potpos var BYTE ;VAR BYTE for Pot Position
    celltemp VAR BYTE ;VAR BYTE for Cell Temperature
    A2D_V VAR BYTE ; Create A2D_V Value to store potpos result
    A2D_V2 Var BYTE ;Create A2D_V2 Value to store cellamps result
    ADCON1=%00000000 ;Sets the Analog to Digital control register
    Start:
    If portc.0 = 0 then portb.6 = 0 'If pin 15 is low, make pin 39 low
    If Portc.0 = 1 then portb.6 = 1 'If pin 15 is high, make pin 39 high
    'When Pin 39 goes high, this turns the
    'pump on! I'm using a Darlington pair
    'to do this (Part # TIP130) It also
    'turns on the "Pump On" LED.
    If portc.3 = 0 then portb.7 = 0 'If pin 18 is low, make pin 40 low
    If portc.3 = 1 then portb.7 = 1 'If pin 18 is high, make pin 40 high
    'When Pin 40 goes high, the "Low Tank
    'Water" LED is turned on!
    debug 1, 14 'Send curser home & Turn Backlight on
    Pause 100 'Pause .1 second
    HPWM 2, 127, 17500 'Output is a 17.5 Khz, 50% duty cycle (pin 16)
    ADCON0=%11001101 'Sets up the AtoD Module to read Channel 1
    ADCIN 1, A2D_V2 'Read channel 1 to A2D_V2 Value
    celltemp= 1+(((300-70)*A2D_V2)/255*2)
    DEBUG "Cell Temp = ", DEC3 celltemp," ", 223, 70," "
    DEBUG "Cell Temp = ", BIN8 celltemp
    Pause 200
    ADCON0=%11000101 'Sets Up the AtoD Module to read channel 0
    ADCIN 0, A2D_V ' Read channel 0 to A2D_V Value
    potpos= 1+(((255-1)*a2d_v)/255)
    Debug "Pot Position = ", DEC3 potpos," "
    Pause 200
    If (potpos <=%00001111)and(potpos <=%00011011) then percent_20 '15 to 27
    Pause 200
    If (potpos <=%00011100)and(potpos <=%00111111) then percent_40 '28 to 63
    Pause 200
    If (potpos <=%01000000)and(potpos <=%01011001) then percent_60 '64 to 89
    Pause 200
    If (potpos <=%01011010)and(potpos <=%01110011) then percent_80 '90 to 115
    Pause 200
    If (potpos <=%01110100)and(potpos <=%01111110) then percent_100 '116 to 126
    If (potpos >=%01011110) Then percent_100
    percent_20: 'Asking for 20% high PWM
    HPWM 1, 51, 17500 'Output is a 17.5 Khz, 20% duty cycle (pin 17)
    DEBUG "PWM = 20%High/80%Low"
    Pause 100
    GoTO start
    percent_40: 'Asking for 40% high PWM
    HPWM 1, 102, 17500 'Output is a 17.5 Khz, 40% duty cycle (pin 17)
    DEBUG "PWM = 40%High/60%Low"
    Pause 100
    GoTO start
    percent_60: 'Asking for 60% high PWM
    HPWM 1, 153, 17500 'Output is a 17.5 Khz, 60% duty cycle (pin 17)
    DEBUG "PWM = 60%High/40%Low"
    Pause 100
    GoTO start
    percent_80: 'Asking for 80% high PWM
    HPWM 1, 204, 17500 'Output is a 17.5 Khz, 80% duty cycle (pin 17)
    DEBUG "PWM = 80%High/20%Low"
    Pause 100
    GoTO start
    percent_100: 'Now at 100% on PWM
    HPWM 1, 254, 17500 'Output is a 17.5 Khz, 100% duty cycle (pin 17)
    DEBUG "PWM = 99%High/01%Low"
    Pause 100
    GoTO start
    You have an ADCON0 assignment just prior to each ADCIN statement.
    That will change the channel and start the conversion immediately without allowing for acquisition time.
    This leaves the voltage from the previous channel in the sample&hold capacitor.
    The ADCIN statement handles ADCON0 for you, so Removing the ADCON0 lines should help.
    You can also reduce the ADC_SAMPLEUS 400 to around 50 or less.
    <br>
  1. 12f675 A/d Miseries
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2008, 03:16
  2. 12F675 A/D and GPIO sleep interrupt
    By macinug in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 15:39
  3. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 20:30
  4. A/D Problems!
    By scottl in forum General
    Last Post: - 20th May 2006, 16:49
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 19:57
