Ds18b20
Results 1 to 25 of 25
Thread: Ds18b20
    Aug 2008
    hi,
    can u please send me picbasic code so i can know where is the error cause i am not god in assembely
    Aug 2008
    hi,
    i try the code u send me but still the same result nochange the resolution still 0.5
    Talking
    Hi, Ahmed
    No surprise ... you do not write tte DS Config Word in the right registers ...
    our friend Fratello saw that ( and corrected it ... )
    a pair of zeros is missing in your command line ...
    Aug 2008
    hi,
    still the same resolution 0.5 even after i update the code , attached is the code u send me if u want to check
    Question Where's the bug ???
    Hi, Ahmed
    I must admit Fratello's program only shows half degrees ... ( just tested on an EasyPic 5 )
    but still have not found Why !!!
    Aug 2008
    hi,
    i am using pic basic pro 2.44 do u think this the problem
    Wink
    Hi, Ahmed
    I Finally got it !!!
    the problem is in the Waiting loop ... that doesn't wait !!!
    sooo... add :
     Busy VAR BIT
    at the top of the program
    and change :
    WaitLoop:
    ' While not DQ                      ' NOT Working !!!
    ' Wend
    by
    WaitLoop:
    OWIn DQ, 4, [Busy] 			' Check for still busy converting
    'PORTC.4 = 1				' Show waiting for conv complete
    If Busy = 0 Then
     GOTO waitloop
    ' PORTC.4 = 0
    Port C.4 was chosen to show the time the DS is Busy ... very useful tool to verify conversion is really complete !!!
    Have fun,
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by ahmed_salah View Post
    hi,
    complied code and also the corrected .asm are attached.
  1. Reading temperature using multi DS18B20
    By KVLV in forum Code Examples
    Last Post: - 3rd November 2017, 20:48
  2. Please help with code for DS18B20
    Last Post: - 28th April 2013, 22:12
  3. Help with DS18B20 program
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2012, 01:50
  4. Multi DS18b20 Code help.
    By sccsltd in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 07:13
  5. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 17:21
