Try this, please and post the results.
hi,
can u please send me picbasic code so i can know where is the error cause i am not god in assembely
hi,
i try the code u send me but still the same result nochange the resolution still 0.5
Hi, Ahmed
No surprise ... you do not write tte DS Config Word in the right registers ...
our friend Fratello saw that ( and corrected it ... )
a pair of zeros is missing in your command line ...
hi,
still the same resolution 0.5 even after i update the code , attached is the code u send me if u want to check
Hi, Ahmed
I must admit Fratello's program only shows half degrees ... ( just tested on an EasyPic 5 )
but still have not found Why !!!
