OWOut DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit] '
OWOut DQ, 1, [$CC, $44] ' Start conversion
WaitLoop:
While not DQ
Wend
OWOut DQ, 1, [$CC, $BE]
OWIn DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]
Convert_Temp:
If Temperature.15 then
Temperature= ~Temperature +1
Twist = 1
Endif
TempC = (Temperature & $7FF) >> 4
Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
Temperature = TempC*100 + Float
If Twist then
V= 10000 - Temperature ' 25 C=12500 0 C=10000 -10 C=9000
Twist = 0
V= 10000 + Temperature
EndIf
' SUBROUTINES:
SelectSign:
If v = 10000 then ' Temperature = 0 C.
Sign=" " ' No sign
Else
If v < 10000 then ' <> 0
Sign="-" ' Temperature below 0 C.
Else
Sign="+" ' Temperature above 0 C.
EndIf
EndIf
DisplayTemp:
If V >= 10000 then ' Above 0 C.
Temperature=V-10000
Else
Temperature=10000-V ' Below 0 C.
EndIf
LcdOut $FE, $C0, Sign, DEC (Temperature / 100), ".", DEC2 Temperature, " ",223,"C "
