Ds18b20
Results 1 to 25 of 25
Thread: Ds18b20
    Aug 2008
    Default Ds18b20
    i have a problem i made temp sensore project based on ds1820 but i want to replace it with ds18B20 for high resolution but when i change it i got strange readings , i think that i have to change something in code can some one help me do that attached is code
    Dec 2008
    Ploiesti, ROMANIA
    OWOut DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit] '
    OWOut DQ, 1, [$CC, $44] ' Start conversion
    WaitLoop:
    While not DQ
    Wend
    OWOut DQ, 1, [$CC, $BE]
    OWIn DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]
    Convert_Temp:
    If Temperature.15 then
    Temperature= ~Temperature +1
    Twist = 1
    Endif
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    If Twist then
    V= 10000 - Temperature ' 25 C=12500 0 C=10000 -10 C=9000
    Twist = 0
    V= 10000 + Temperature
    EndIf
    ' SUBROUTINES:
    SelectSign:
    If v = 10000 then ' Temperature = 0 C.
    Sign=" " ' No sign
    Else
    If v < 10000 then ' <> 0
    Sign="-" ' Temperature below 0 C.
    Else
    Sign="+" ' Temperature above 0 C.
    EndIf
    EndIf
    DisplayTemp:
    If V >= 10000 then ' Above 0 C.
    Temperature=V-10000
    Else
    Temperature=10000-V ' Below 0 C.
    EndIf
    LcdOut $FE, $C0, Sign, DEC (Temperature / 100), ".", DEC2 Temperature, " ",223,"C "
    Aug 2008
    hi,
    thanks for replay but i am beginner in pbp so can u guide me where is the part i have to replace in my old code
    Aug 2008
    hi,
    i update the code u send me before can u check it please soi can begin testing
    Wink
    Hi, Ahmed
    This subject in the SEARCH function of the Forum Gives 72 Hits ... including working programs for the 18B20
    so, just use it !!!
    Aug 2008
    hi,
    no replies nothing work tell now i got blank screen
    Dec 2008
    Ploiesti, ROMANIA
    Put here the schematic, please.
  1. Reading temperature using multi DS18B20
    By KVLV in forum Code Examples
    Last Post: - 3rd November 2017, 20:48
  2. Please help with code for DS18B20
    By fratello in forum mel PIC BASIC Pro
    Last Post: - 28th April 2013, 22:12
  3. Help with DS18B20 program
    By presario1425 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2012, 01:50
  4. Multi DS18b20 Code help.
    By sccsltd in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 07:13
  5. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 17:21
