Cash dispenser
Results 1 to 2 of 2
Thread: Cash dispenser
    tigerflow's Avatar
    tigerflow Guest
    Default Cash dispenser
    I want the program to write "peddobears says:" "cash flow" when the code "5354" is writen out on the display, but it doesn't work. Instead it just keeps going (You can keep writing numbers even if you have written 5354 out on the display). Someone who knows what is wrong?
    define loader_used 1
    ' Define LCD connections
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    ' Define program variables
    col VAR BYTE ' Kolumn
    row VAR BYTE ' Rad
    key VAR BYTE ' Tangent
    code var byte
    OPTION_REG.7 = 0 ' Enable PORTB pullups
    TRISB = %11110000
    ADCON1 = 7 ' Make PORTA and PORTE digital
    Low PORTE.2 ' LCD R/W low (write)
    Pause 500 ' Wait for LCD to start
    LCDOut $FE, 1
    loop: gosub key_encode ' Avkoda tangent
    if key = $FF then loop ' Tillbaka om ingen är nedtryckt
    iF KEY < 9999 THEN ' Kolla om siffra tryckts
    code = KEY
    LCDOut $FE,$0f, #key ' "fisk" och skriv tangent
    IF key = $20 THEN ' Kolla om A tryckts = lagra
    WRITE 0, code ' Lagra adval i EEPROM adress 0
    LCDOut $FE, 1, "Save ", #code ' Skriv meddelande
    IF key = $21 THEN ' Kolla om B tryckts = läsa
    READ 0, code ' Läser från EEPROM adress 0 till code
    LCDOut $FE, 1, "Read ", #code ' Skriv meddelande
    if code = 5453 then
    goto loop2
    loop1: gosub key_encode ' Avkoda tangent
    IF key <> $FF then loop1 ' Vänta tills ej tryckt
    GoTo loop ' Tillbaka
    loop2:
    PAUSE 800
    LCDOUT $FE,1, "PeddoBear Says:"
    LCDOUT $Fe,$C0, "Cashfhlow <3"
    Pause 1000
    goto loop
    key_encode:
    pause 50
    key = 0
    PORTB = %11111110 ' kolla rad 1
    if PORTB = %11111110 then key_1
    row = 1
    goto pressed
    key_1: PORTB = %11111101 ' kolla rad 2
    if PORTB = %11111101 then key_2
    row = 2
    goto pressed
    key_2: PORTB = %11111011 ' kolla rad 3
    if PORTB = %11111011 then key_3
    row = 3
    goto pressed
    key_3: PORTB = %11110111 ' kolla rad 4
    if PORTB = %11110111 then no_key
    row = 4
    goto pressed
    no_key: key = $FF
    pressed:
    key = PORTB & %11110000
    if key = %01110000 then col = 4
    if key = %10110000 then col = 3
    if key = %11010000 then col = 2
    if key = %11100000 then col = 1
    key = col + ((row - 1) * 4)
    SELECT case key
    CASE 1
    key = 1
    CASE 2
    key = 2
    CASE 3
    key = 3
    CASE 4
    key = $20 ' Tangent A = lagra
    CASE 5
    key = 4
    CASE 6
    key = 5
    CASE 7
    key = 6
    CASE 8
    key = $21 ' Tangent B = läsa
    CASE 9
    key = 7
    CASE 10
    key = 8
    CASE 11
    key = 9
    CASE 12
    key = $FF ' Ej använd
    CASE 13
    CASE 14
    key = 0
    CASE 15
    CASE 16
    END SELECT
    May 2008
    Italy
    Welcome to the forum.
    Your variable "code" has been declared as byte, so max nunber it could contains is 255. Declare variable code as Word and adjust your source code accordingly.
    Al.
  1. Word and REV and ~
    By cmolson in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 19:22
