Programming Problem PIC12F683
Results 1 to 14 of 14
    Which ZIF adapter are you using?
    Bruce,
    I'm using the 8-40 ZIF adapter. On the under side of the adapter on the board it says 03221 JMS. The cable from the programmer is plugged into the 8-18 connector and pin number 1 on the IC is lined up with Pin 1: 8-18.
    ~ Dave
    Sounds like you have it connected right. If you have a 2nd 12F683 to test, and that one
    won't program either, I would contact MeLabs support directly.
    The only problems I'm aware of on the older 840Z 03221 ZIF adapter series were for 18F
    parts which required a modification for AVdd connections to pin #7.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2007
    USA, CA
    One other thing to check... if you've already programmed the chip once. Make sure your programmer is set to high voltage programming.
    Problem solved. I downloaded Beta Software for EPIC™ Programmer, including the update for the firmware and the programmer works great now. On the download page, there is the following statement "It does not support the advanced command-line switches of the paid upgrade." I don't know what that means for me.
    ~ Dave
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 18:39
  2. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 05:21
  3. RFID medicine teller!! problem with programming
    By sknee8787 in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 18:31
  4. Programming Problem with PIC16F819
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th July 2007, 19:42
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 01:02
