Programming Problem PIC12F683
Results 1 to 14 of 14
    Which ZIF adapter are you using?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce,
    I'm using the 8-40 ZIF adapter. On the under side of the adapter on the board it says 03221 JMS. The cable from the programmer is plugged into the 8-18 connector and pin number 1 on the IC is lined up with Pin 1: 8-18.
    ~ Dave
    Sounds like you have it connected right. If you have a 2nd 12F683 to test, and that one
    won't program either, I would contact MeLabs support directly.
    The only problems I'm aware of on the older 840Z 03221 ZIF adapter series were for 18F
    parts which required a modification for AVdd connections to pin #7.
    -Bruce
    tech at rentron.com
    Sep 2007
    USA, CA
    One other thing to check... if you've already programmed the chip once. Make sure your programmer is set to high voltage programming.
    Problem solved. I downloaded Beta Software for EPIC™ Programmer, including the update for the firmware and the programmer works great now. On the download page, there is the following statement "It does not support the advanced command-line switches of the paid upgrade." I don't know what that means for me.
    ~ Dave
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 18:39
  2. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 05:21
  3. RFID medicine teller!! problem with programming
    By sknee8787 in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 18:31
  4. Programming Problem with PIC16F819
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th July 2007, 19:42
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 01:02
