how to generating video signals?
Results 1 to 9 of 9
    Apr 2009
    Default how to generating video signals?
    im trying to findout how to generat video signal using pbp i found a few projects in asm but i dont know assembly language any one can help me in pbp ?
    Sep 2007
    USA, CA
    PBP does not have the precision to generate video, unless you understand the asm produced. You'll most likely find it easier to retrofit some asm code than try to reinvent it with pbp.
    Apr 2009
    it seems to me very hard to learn asm bcz i tryed before i couldent take it in my main and they didnt explain good the instrictions, i lose in them, well thank you for a good ideas,
    Dec 2005
    So Cal and loving it
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Apr 2009
    Default coffee
    i checked that link ,i had it before,but the problem is its seems to me we can send anything like asm code does output of pic ,i just wanted to know the frequency i need for the video signal and the syncronisation, thank you both for the answers, i will try again and again im reading some asm examples and comparing them with pbp ,
    Quote Originally Posted by malwww View Post
    First thing need to know is which standard video are you interested in, NTSC, PAL, SECAM ? The second is what are you trying to do ?
    Feb 2005
    Kolkata-India
    Default Have a look at this
    This link can be useful
    http://www.micro-examples.com/public...ic-pal-tv.html
    (Written in mikroC )
    also take a look at the PICO OSD
    Sougata
    Apr 2009
    hi joe, i need to generate pal video and creat some movine txt on the tv screen like mire tv or atv if u have seen it,
    and thank you sougata for the link ,i will check it out ..
    Apr 2009
    Question
    im still trying but it doesnt work any more ideas about video generate? thanks all the forum....
  1. Generating a composite video signal with PIC
    Last Post: - 2nd August 2008, 03:46
  2. How to switch between video inputs
    Last Post: - 5th May 2008, 13:27
  3. 3.3v signals to 5v signals
    By InitialDriveGTR in forum Schematics
    Last Post: - 7th February 2007, 23:43
  4. RF video reciever - digital tuning
    By RYTECH in forum Schematics
    Last Post: - 15th September 2006, 01:05
  5. Generating RF from a PIC
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 21:26
