Problem with multiple interrupts
Results 1 to 8 of 8
    May 2008
    Italy
    Default Problem with multiple interrupts
    Dear friends, I am trying to make two pic16F88 to serially communicate between them.
    Pic_A Pic_B
    portB.6 (Tx) >-------------------------> portB.7 (Rx)
    portB.7(Rx) <-------------------------< portB.6(Tx)
    To be sure to have a reliable communication, I am using DT int on portB.0 to activate serial transmission as per the code below.
    INCLUDE "Modedefs.bas"
    INCLUDE "DT_INTS-14_3.bas"   ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
    ANSEL = 0
    CMCON = 7
    OPTION_REG.6 = 1
    TrisA = %00010000
    TrisB = %10000101
    PortA = 0
    DEFINE OSC 8
    DEFINE HSER_SPBRG 12  ' 9600 Baud @ 8MHz, 0,16%
    SCall       var     PortB.3
    PwrL        var     PortA.0
    PwrM        var     PortA.1
    Led         var     PortA.2
    Buz         var     PortA.3
    STx         var     PortB.6
    SRx         var     PortB.7
    ZCrox       var     PortA.4
    X10Tx       var     PortB.1
    TxEnable    var     PortB.4
    low TxEnable
    low SCall
    input SRx
    high STx
    A0              var Byte
    DataFlag        var byte
    House           var byte
    Unit            var Byte
    Job             var Byte
    Rdata           var Byte[30]
    Flag0           var dataflag.0
    Flag1           var DataFlag.1   ' Hserin interrupt channel
    Flag2           var dataFlag.2   ' PortB.0 interrupt channel
    Flag3           var DataFlag.3
    Flag7           var dataFlag.7
    '-------------------- Rx & PB0 DT interrupt definition -----------------
            INT_Handler    RX_INT,   _Getbytes,     PBP,  yes
            INT_Handler    INT_INT,  _DataReady,    PBP,  yes
    @     INT_ENABLE  RX_INT     ; enable RX_INT interrupts
    gosub Buzzer
    low led
    A0=0
    DataFlag=0
    hserout ["System Ready",10,13]
    pause 1
    IF Rdata[0] = 36 and Flag0 = 1 then
    High led
    If Rdata[1] = 49 then
    House = ((Rdata[4]-48)*10) + (Rdata[5]-49)  ' X10 house value
    Unit = ((Rdata[6]-48)*10) + (Rdata[7]-49)   ' X10 Unit value
    Flag7 = 0
    If Rdata[8] = 49 then Job = 18 : Flag7 = 1
    If Rdata[8] = 50 then Job = 26 : Flag7 = 1
    If Rdata[8] = 98 then Job = 20: Flag7 = 1
    If Rdata[8] = 99 then Job = 28: Flag7 = 1
    if Flag7 = 0 Then Skip00
    High TxEnable                               ' enable X10 transmission
    pause 1                                     ' delay before X10 Tx
    Xout X10Tx,Zcrox,[House\Unit,House\Job]     ' X10 transmission
    low TxEnable                                ' disable X10 Transmission
    goto Skip00
    Endif
    If Rdata[1] = 52 then     ' intra system comand
    If Rdata[8] = 250 then gosub Power01
    If Rdata[8] = 240 then gosub Power02
    If Rdata[8] = 230 then gosub Modem01
    If Rdata[8] = 220 then gosub Modem02
    goto Skip00
    If Rdata[1] = 51 then     ' intra system communication
    High Scall
    Pause 10
    serout2 STx,84,5,[str Rdata\30]
    Low Scall
    goto Skip00
    IF Rdata[1] = 57 and Flag2 = 1 then        ' send out via wifi string recived
        hserout [str Rdata\30]
    Skip00:                                     ' reset main pointers & flag
    Rdata[0] = 0
    Rdata[1] = 0
    Rdata[2] = 0
    Rdata[8] = 0
    Flag0 = 0
    Flag1 = 0
    Flag2 = 0
    A0=0
    gosub buzzer
    Low led
    goto Main
    Getbytes:                                   ' Rx interrupt data from Xbee module
    hserin 100, Nodata, [Str Rdata\9]
    Flag0 = 1
    @ INT_RETURN
    Nodata:
    Flag0 = 0
    Flag1 = 1
    @ INT_RETURN
    DataReady:                                  ' Intracom interrupt data from chip
    hserout ["PB0 Interrupt"]  ' this message never show up
    Flag0 = 0
    Flag1 = 0
    Flag2 = 0
    serin2 STx,84,500,JumpOut,[str Rdata\30]
    Flag2 = 1
    Flag0 = 1
    Loop:
    if PortB.0 = 1 then Loop
    @ INT_RETURN
    JumpOut:
    Flag0 = 0
    Flag1 = 0
    Flag2 = 0
    Flag3 = 1
    @ INT_RETURN
    Power01:
    hserout ["PowerLine Off",10,13]
    pause 1
    low PwrL
    Power02:
    hserout ["PowerLine On",10,13]
    pause 1
    high PwrL
    Modem01:
    hserout ["Modem Off",10,13]
    pause 1
    low PwrM
    Modem02:
    hserout ["Modem On",10,13]
    pause 1
    high PwrM
    Buzzer:
    high buz
    pause 20
    low buz
    The Rx interrupt works fine, while the portB.0 interrupt doesn't work at all, so I am anable to get data transfer between the two pics.
    There must be something wrong but I am anable to find it! Any help will be greatly appreciated.
    Al.
    Probably just need to ...
    @     INT_ENABLE  INT_INT
    May 2008
    Italy
    Yes Darell that was the missing part! Thank you very much indeed for the help.
    Al.
    Sniff sniff,I smell something interesting here.
    If I may ask, what are you cooking? Wifi was the trigger to be curious!
    May 2008
    Italy
    Ioannis , The project is called "Home Automation to the maximum possible extent" naturally I am doing it in my house, and as you can imagine from the title, the project is in continuos evolution.
    At present, I have almost all the appliances; lamps and blinders controlled via X10, plus 16 digital inputs to control various sensors, and 16 digital outputs to control non X10 devices.
    So far, I can control and monitor my house in several ways (PC; SMS; Timers and local keypads), I am working to be able to do it also via web.
    Al.
    Nice Al.
    Most control are trivial I believe although some care is needed in the design. Web is the most impressive one.
    Good luck in the project.
    I am also doing something similar with Zigbee devices for local communication and am looking for the web thing later (now our 3rd kid is coming, so...)
    May 2008
    Italy
    These are really great projects! congratulation Ioannis
    Al.
    Oh, thanks. Yes they are indeed!
    Well, I am leaving now fr the deliver!
  1. 16F946 Instant Interrupts problem
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 14th April 2009, 22:20
  2. General Question About Multiple Interrupts
    By grzeh666 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2008, 17:09
  3. Darrel Taylor Interrupts I2C Problem
    By dcorraliza in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 02:13
  4. Handeling multiple Interrupts
    By BobSpencerr in forum General
    Last Post: - 1st March 2007, 01:12
  5. Turning on & off multiple interrupts
    Last Post: - 30th June 2005, 17:50
