I strongly disagree with this. First, in this particular example, he's using Ai as a constant, not a changing variable. That allows you to change PICs (or PIC pins), and just change the setup constant, without searching for all of the references to the pin.
Second, there is nothing wrong with using a variable variable to read adcin.
What you did do wrong, however, is you referenced the AN# with a PORT#. You don't do that. You should only use the ANx number; in this case, assuming your comments are your target, 6, NOT Portb.7.
Correct:
adcin 6, bat
NOT Correct:
adcin portb.7, bat
Correct:
Ai var 6 'Notice we use "x" of ANx.
adcin Ai, bat
NOT Correct:
Ai var portb.7 'Do NOT use the Port pin the ANx is on.
adcin Ai, bat
