Kind of stuck
Results 1 to 7 of 7
Thread: Kind of stuck
    May 2009
    Default Kind of stuck
    Hello,
    Ive got a really simple problem but i cannot see why i can not sort it.
    Im using a K8048 board with the standard 18pin 16F627A pic. Ive managed to hook it up and ive compiled the blink app in mplab and put it on the pic fine.
    The problem is ive tried to drop a if statement in as i thought it was a simple enough thing to do next. Only problem is it does not work
    This is the code ive done
    OPTION_REG = %11010111	'Set PIC options (See datasheet).
    TRISA = %11111111	'all RA ports are inputs
    TRISB = %11000000 	'RB7 & RB6 are inputs.RB5...RB0 are outputs.
    led1 var portB.0
    led2 var portB.1
    sw1 var portA.0
    loop:
    	if sw1 = 1 then	Goto loop
    	high led1          ' Turn on LED connected to PORTB.0
    	low led2
            Pause 500       ' Delay for .5 seconds
           	low led1          ' Turn off LED connected to PORTB.0
    	high led2
            Goto loop       ' Go back to loop and blink LED forever
    This is part of the schematic for the k8084
    Ive looked at the code and ive got the A bank set as an input, and the push button goes to RA0.
    Any ideas where ive gone wrong, and sorry for such a dumb problem
    Try CMCON = 7
    It disabled comparators on Port A
    May 2009
    thanks loads Joe,
    That worked a treat. As my second app, ive just changed my app to do the knight rider led thing.
    Thanks again
    Trev
    Different pics would require different arguments to achieve this; disable the comparator, disable the adc and so on.
    Make things simpler for yourself; just add darrel Taylor's alldigital.pbp as an include to your code to never having to bother remembering it in the future. Available at http://www.picbasic.co.uk/forum/showthread.php?t=11100
    Anand
    SWITZERLAND (french speaking)
    Default K2000
    Hi Trev,
    I did something similar a year ago http://home.citycable.ch/flotulopex/...0_Frames_e.htm
    Maybe this gives you some other ideas
    Roger
    May 2009
    thanks for the replys guys, im loving the idea of being able to just code a pic to do stuff that would take a fair circuit to do.
    Ill add that all digital file to my pic programming stuff.
    Is there any good book that talks of good programming practices with pics, ie use this command instead of that ect?
    Thanks again
    Trev
    Quote Originally Posted by gti_uk View Post
    Trev
    . . . BRUCE is still writing it . . .
  1. lcd stops after about 5 minutes and gets stuck
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 15th September 2009, 12:03
  2. Stuck with 85C temp on ds18b20
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2009, 19:50
  3. Getting Stuck in loop
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 19th November 2008, 15:46
  4. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 01:15
  5. MPLAB Quickbuild stuck on
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 9th July 2006, 02:52
