Need Help
Results 1 to 5 of 5
Thread: Need Help
    May 2009
    Unhappy Need Help
    Need help with the following
    define LOADER_USED 1
    Define Lcd_dreg Portc
    Define Lcd_dbit 0
    Define Lcd_rsreg Portc
    Define Lcd_rsbit 4
    Define Lcd_ereg Portc
    Define Lcd_ebit 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2 'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50
    Define Osc 4 ' We're using a 4 MHz oscillator
    RELAY1 VAR PORTB.0 ' RELAY 1
    RELAY2 VAR PORTB.1 ' RELAY 2
    RELAY3 VAR PORTB.2 ' RELAY 3
    RELAY4 VAR PORTB.3 ' RELAY 4
    RELAY5 VAR PORTB.4 ' RELAY 5
    RELAY6 VAR PORTB.5 ' RELAY 6
    RELAY7 VAR PORTB.6 ' RELAY 7
    RELAY8 VAR PORTB.7 ' RELAY 8
    'RELAY VAR BYTE ' RELAY NUMBER
    MYDATA VAR byte [2] ' GENERAL PURPOSE DATA VARIABLE
    INDEX VAR byte ' SMS INDEX NUMBER
    'I VAR BYTE
    Trisa = %00000000 ' SETS ALL PORTA PINS TO OUTPUT
    Trisb = %00000000 ' ALL OUTPUT
    adcon1 = 7
    trisc = %00000000
    Pause 50'0 ' Wait .5 second
    Lcdout $fe,1, "SMS CONTROL" ' Send to LCD
    Lcdout $fe,$C0, "SMS TEST C5" ' Second Line
    PAUSE 20'00
    LOOP:
    mydata=0
    Lcdout $fe, 1, "WAITING 4 SMS" ' Send to LCD
    Pause 50'00
    hserout ["AT+CMGL=",34,"REC UNREAD",34,13]
    hserin 2000,loop,[WAIT("+CMGL:"), SKIP 1 , DEC INDEX] 'From Modem
    Lcdout $fe, $C0, "SMS RX: " ,dec index' Second Line
    PAUSE 50'00
    Lcdout $fe, 1, "READ MSG: " ' Send to LCD
    hserout ["AT+CMGR=",dec index,13]
    hserin [WAIT("+CMGR:"),SKIP 55,str MYDATA\2]
    pause 20
    hserout [str MYDATA\2,13]
    pause 20
    Lcdout $fe, 1,"MYDATA:",str mydata\2 ' Send to LCD
    pause 20
    SELECT CASE mydata
    CASE 33
    Lcdout $fe, 1, "RELAY 2"
    Lcdout $fe, $C0, "ON"
    pause 20
    CASE 44
    Lcdout $fe, $C0, "OFF"
    pause 20
    CASE 11
    Lcdout $fe, 1, "RELAY 1"
    pause 20
    CASE 22
    pause 20
    CASE 55
    Lcdout $fe, 1, "RELAY 3"
    pause 20
    CASE 66
    pause 20
    CASE 77
    Lcdout $fe, 1, "RELAY 4"
    pause 20
    CASE 88
    pause 20
    end select
    PAUSE 80'00
    Lcdout $fe, 1, "DELETE SMS MSG"
    Lcdout $fe, $C0, "#:" ,dec index
    hserout ["AT+CMGD=",dec index, 13]
    PAUSE 30'00
    GOTO LOOP
    Program does not excecute the CASE statements
    HELP PLEASE
    Jan 2006
    Istanbul
    " MYDATA VAR byte [2] " is an array.
    You have "mydata" in your Select case statement.
    Chose one element from mydata elements.
    May 2009
    Cool Need help
    To make it an Array was the only way I could read the value of Mydata
    If I make it a normal variable this command does not work
    hserin [WAIT("+CMGR:"),SKIP 55,str MYDATA]
    does not get last of SMS message fot instance if I say message is 22 to switch on relay 22
    Have played around with skip value's from 49 to 56
    May 2009
    Cool help needed
    hserin [WAIT("+CMGR:"),SKIP 55, DEC MYDATA]
    correction to above
    Then you will have to figure out if it is mydata[0] or mydata[1] that stores the variable you want. Change your mydata= 0 and select case mydata to mydata[0]=0 or mydata[1]=0 and select case mydata[0] or select case mydata[1]
    http://www.scalerobotics.com
