Protect PIC's input against "high" voltage using AD
Results 1 to 11 of 11
Threaded View
  1. #9
    flotulopex they are some batteries there,
    I did a battery anayliser to test 6V batteries based on the alphabat pro, It works really well, The only real way to test batteries is the discharge method, It uses a pic18f4520,GLCD & SD_CARD for recording the date,time,battery and current draw, This unit works very well.
    If you want accuracy then have a look at the attached file, It's part of a schematic from a fluke meter and it ues a 10bit A/D converter, You could can control the auto ranging through the PIc and if need be you could always use a 12-24Bit A/D chip. If I rmember the max DC voltage is 600V, This is one of my next projects.
    have you thought about hard wiring the unit to the batteries and using RF or RS232 way, You could have one or two master units then salves units to send data and why not go all the way, Use a SD_Card so log the voltage and you can upload the data into EXcel These are just some ideas but it would amake it cool project
  1. Temp readings and voltage input
    Last Post: - 7th July 2008, 12:35
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  3. AD input and 7segment dysplay output
    Last Post: - 16th November 2007, 13:45
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. measuring input voltage
    By thon in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 16:03
