Thank you Joe,
Unfortunately the PAUSE 1000 within my main loop is making the response too slow.
This is my main loop ( added your example) when I press on any of the 6 switches it needs to react faster than a second later. This is why I am thinking I probably need to use timer1.
    l=0: y=0
    WHILE !T0IF : WEND           ; wait for timer to overflow
    TMR0 = 193                   ; load timer for 1ms
    T0IF = 0                     ; reset the overflow flag
    IF (SW1=0) THEN Counters[0] = DelayTime : goto Channel1
    IF (SW2=0) THEN Counters[1] = DelayTime : goto Channel2
    IF (SW3=0) THEN Counters[2] = DelayTime : goto Channel3
    IF (SW4=0) THEN Counters[3] = DelayTime : goto Channel4
    IF (SW5=0) THEN Counters[4] = DelayTime : goto Channel5
    IF (SW6=0) THEN Counters[5] = DelayTime : goto Channel6
    FOR X = 0 to 5                      ; cycle thru counters
      IF Counters(X) > 0 THEN           ; if counter is counting
         Counters(X) = Counters(X) - 1  ; decrement counter
         IF Counters(X) = 0 THEN        ; if counter timed out
           SELECT CASE X                ; turn on the appropriate LED
             CASE 0 : if led1 = 1 then gosub StartCharge1
             CASE 1 : if led2 = 1 then gosub StartCharge2
             CASE 2 : if led3 = 1 then gosub StartCharge3
             CASE 3 : if led4 = 1 then gosub StartCharge4
             CASE 4 : if led5 = 1 then gosub StartCharge5
             CASE 5 : if led6 = 1 then gosub StartCharge6
           END SELECT
    NEXT X
;               update counter                    /
    counter = counter + 1
    Pause 1000
    If counter >= 60 then minutes  = minutes + 1 : counter = 0
    ; trigger off if it is time
    if minutes >= 720 then minutes = 0
GOTO Main
