Delayed output 10 secs
Results 1 to 38 of 38
    The T1CON.0 = 0 line is turning off the Timer.
    So it never counts again.
    At the start of the program, the SecondsChanged bit is set so that programs will display the initial 00:00:00.
    So it stops counting before the first second passes.
    May 2009
    Montreal, QC, Canada
    Some days I feel dumber than others and today is one of those!
    I tried joining this code with my code and things are not going so well... I have a piezo beeping on the press of the swithes and when I added this code it is more like rigning than beeping and also I have a feeling I need something short and simple but I am trying to use something big and complex.
    All I really need is to have a counter that counts the minutes up to 720 and then cycle to 0 and start over endlessly. I don't need an interupt as I can test compare by branching from the main loop (in one minute I have plenty of time to test) Accuracy is not really important + or - 10 minutes over 720 is ok. I am already using timer0 so I guess I need to use timer1 or timer2.
    Do you have any simple and quick advice or link to suggest?
    I feel I have taked already too much of your time and I apologize for that.
    Mike
    Quote Originally Posted by lilimike View Post
    Mike
    Hi Mike,
    Welcome to My World!
    counter var byte
    minutes var word
    clear  ' zero variables at start
    loop:
    PortB  = %00000000
    TRISB  = %00000000
    counter = counter + 1
    Pause 1000
    If counter >= 60 then minutes  = minutes + 1 : counter = 0
    if minutes >= 720 then gosub action
    goto loop
    Action:
    minutes = 0
    Toggle PortB.1 ' change this to do what you need done
    A great clock this will not be, it does (should do) what you asked, you may need to juggle the numbers if you have a bunch of code to stuff in.
    May 2009
    Thank you Joe,
    Unfortunately the PAUSE 1000 within my main loop is making the response too slow.
    This is my main loop ( added your example) when I press on any of the 6 switches it needs to react faster than a second later. This is why I am thinking I probably need to use timer1.
        l=0: y=0
        WHILE !T0IF : WEND           ; wait for timer to overflow
        TMR0 = 193                   ; load timer for 1ms
        T0IF = 0                     ; reset the overflow flag
        IF (SW1=0) THEN Counters[0] = DelayTime : goto Channel1
        IF (SW2=0) THEN Counters[1] = DelayTime : goto Channel2
        IF (SW3=0) THEN Counters[2] = DelayTime : goto Channel3
        IF (SW4=0) THEN Counters[3] = DelayTime : goto Channel4
        IF (SW5=0) THEN Counters[4] = DelayTime : goto Channel5
        IF (SW6=0) THEN Counters[5] = DelayTime : goto Channel6
        FOR X = 0 to 5                      ; cycle thru counters
          IF Counters(X) > 0 THEN           ; if counter is counting
             Counters(X) = Counters(X) - 1  ; decrement counter
             IF Counters(X) = 0 THEN        ; if counter timed out
               SELECT CASE X                ; turn on the appropriate LED
                 CASE 0 : if led1 = 1 then gosub StartCharge1
                 CASE 1 : if led2 = 1 then gosub StartCharge2
                 CASE 2 : if led3 = 1 then gosub StartCharge3
                 CASE 3 : if led4 = 1 then gosub StartCharge4
                 CASE 4 : if led5 = 1 then gosub StartCharge5
                 CASE 5 : if led6 = 1 then gosub StartCharge6
               END SELECT
        NEXT X
    ;               update counter                    /
        Pause 1000
        ; trigger off if it is time
        if minutes >= 720 then minutes = 0
    GOTO Main
    Well, that in itself implies there are days when you don't feel that way ...
    Only prior instances of feeling "Smart" can make you recognize the "dumb" when it comes around.
    Let's see if we can't make tomorrow a little better.
    At first I was trying to make it easy with an example Without Interrupts.
    Then you found my interrupt program, and the Elapsed Timer.
    Combining the two has no doubt created the headaches.
    I've tried to figure out what you were doing from the previous posts, and failed.
    If I could see what you had so far, I might be able to combine things using only DT_INTS.
    Who knows?
    May 2009
    Ok so in many occasions I felt like just putting up all my code but then I felt embarassed knowing how many people wil laugh...
    But here it is.
    This is what I am trying to do:
    I have 6 switches SWx, 6 LEDs LEDx and 6 Optoisolator (which will trigger TRIACS) TRx
    Normal mode:
    if I press SW1, it will turn on LED1 and wait 10 seconds before turning on TR1.
    The 10 seconds is just to wait in case I wanted to get in program mode.
    Program mode:
    Happens if I keep SW1 pressed for about 5 seconds. LED1 will blink 11 times and the program is waiting for user input on SW1 during 5 seconds. each press of SW1 will blink LED1 once. after 3 seconds of inactivity of SW1, LED1 wil blink the amount of time SW1 was pressed during program mode. if pressed 5 times during program mode LED1 will blink 5 times and it will save value 5 in EEPROM address 0. After this, going back to normal mode, if I press SW1, LED1 will go high, 10 seconds later TR1 will go high.
    If I press SW1 again LED1 and TR1 will go low. If I don't press SW1, LED1 and TR1 will go low after 5 hours (value in EEPROM)
    My default time value is 3 hours, minimum is 1 and max is 12 (720 min.)
    At this point my code is (seams to be) working perfectly with the exception that I don't know how to test when the time is up. of course I need to keep track of 6 TR.
    I ment to narrow down my code using indexes for all ports but my testing didn't go as planned so I have everything repeated 6 times.
    PLease don't laugh
    CLEAR
    INCLUDE "AllDigital.pbp"         ; Disable Analog functions
    DEFINE OSC 8
    OSCCON = %01110001
    SW1     VAR PORTB.0
    SW2     VAR PORTB.1
    SW3     VAR PORTB.2
    SW4     VAR PORTB.3
    SW5     VAR PORTB.4
    SW6     VAR PORTB.5
    LED1    VAR PORTC.0
    LED2    VAR PORTC.1
    LED3    VAR PORTC.2
    LED4    VAR PORTC.3
    LED5    VAR PORTC.4
    LED6    VAR PORTC.5
    PZ      VAR PORTC.6               ; piezo (beep)
    TR1     VAR PORTA.0
    TR2     VAR PORTA.1
    TR3     VAR PORTA.2
    TR4     VAR PORTA.3
    TR5     VAR PORTA.4
    TR6     VAR PORTA.5
    SwStat  Var bit                  ; used to control toggle of SWx
    L       var byte                 ; count SWz time hold
    I       VAR byte                 ; general use in for next
    Counters   VAR WORD[6]           ; 6 words, for 6 buttons
    ChargeTime VAR WORD[6]           ; charging time in hours
    DelayTime  CON 10000             ; 10 seconds
    T0IF       VAR INTCON.2          ; TMR0 overflow flag
    X          VAR BYTE
    Y          var byte
    OPTION_REG = %01010100           ; WPU on, TMR0 1:32 prescaler, internal clk
    PAUSE 50                         ; let everything settle
    ;  First time use, check if Charging time is configured.                 /
    ;  if not, set defaults to 3 hours. (EEPROM 0 to 5 =3 and 6=0x25         /
    read 6,y             ; if not 0x25 then it is the first time
    if y <> $25 then
        for I = 0 to 5: write i,3: next i: write 6,$25
        l=0: y=0
               END SELECT
        NEXT X
    GOTO Main
    my code is too long, the rest is in the next message
    May 2009
    here is the rest...
    Channel1:
        pause 25                                  ; debounce
        if sw1 = 0 then
            if led1 = 0 or swstat = 1 then
                if led1 = 0 then sound pz,[123,10]: high led1
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led1: sound pz,[123,10]: pause 50: next i
                    goto Bprog1
                    goto Channel1
                low led1: low tr1: sound pz,[123,10]
            while sw1 = 0: wend
        swstat = 0
    Channel2:
        pause 25                                  ; debounce
        if sw2 = 0 then
            if led2 = 0 or swstat = 1 then
                if led2 = 0 then sound pz,[123,10]: high led2
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led2: sound pz,[123,10]: pause 50: next i
                    goto Bprog2
                    goto Channel2
                low led2: low tr2: sound pz,[123,10]
            while sw2 = 0: wend
        swstat = 0
    Channel3:
        pause 25                                  ; debounce
        if sw3 = 0 then
            if led3 = 0 or swstat = 1 then
                if led3 = 0 then sound pz,[123,10]: high led3
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led3: sound pz,[123,10]: pause 50: next i
                    goto Bprog3
                    goto Channel3
                low led3: low tr3: sound pz,[123,10]
            while sw3 = 0: wend
        swstat = 0
    Channel4:
        pause 25                                  ; debounce
        if sw4 = 0 then
            if led4 = 0 or swstat = 1 then
                if led4 = 0 then sound pz,[123,10]: high led4
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led4: sound pz,[123,10]: pause 50: next i
                    goto Bprog4
                    goto Channel4
                low led4: low tr4: sound pz,[123,10]
            while sw4 = 0: wend
        swstat = 0
    Channel5:
        pause 25                                  ; debounce
        if sw5 = 0 then
            if led5 = 0 or swstat = 1 then
                if led5 = 0 then sound pz,[123,10]: high led5
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led5: sound pz,[123,10]: pause 50: next i
                    goto Bprog5
                    goto Channel5
                low led5: low tr5: sound pz,[123,10]
            while sw5 = 0: wend
        swstat = 0
    Channel6:
        pause 25                                  ; debounce
        if sw6 = 0 then
            if led6 = 0 or swstat = 1 then
                if led6 = 0 then sound pz,[123,10]: high led6
                pause 300
                swstat = 1
                l=l+1
                if l => 5 then
                    for i = 1 to 11: toggle led6: sound pz,[123,10]: pause 50: next i
                    goto Bprog6
                    goto Channel6
                low led6: low tr6: sound pz,[123,10]
            while sw6 = 0: wend
        swstat = 0
    Bprog1:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(0) > 0 THEN Counters(0) = Counters(0) - 1
        IF Counters(0) = 0 THEN
            if y = 0 then y = 3
            if y > 12 then y = 12
            write 0,y
            for I = 1 to y: high led1:sound pz,[123,10]:pause 50:low led1: pause 50: next i
        if sw1 = 0 then
            pause 25                        ;debouce
            if sw1 = 0 then
                high led1: sound pz,[123,10]: pause 25
                y = y + 1: low led1
        goto bprog1
    Bprog2:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(1) > 0 THEN Counters(1) = Counters(1) - 1
        IF Counters(1) = 0 THEN
            if y = 0 then y = 3
            write 1,y
            for I = 1 to y: high led2:sound pz,[123,10]:pause 50:low led2: pause 50: next i
        if sw2 = 0 then
            pause 25                        ;debouce
            if sw2 = 0 then
                high led2: sound pz,[123,10]: pause 25
                y = y + 1: low led2
        goto bprog2
    Bprog3:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(2) > 0 THEN Counters(2) = Counters(2) - 1
        IF Counters(2) = 0 THEN
            if y = 0 then y=3
            write 2,chargetime(2)
            for I = 1 to y: high led3:sound pz,[123,10]:pause 50:low led3: pause 50: next i
        if sw3 = 0 then
            pause 25                        ;debouce
            if sw3 = 0 then
                high led3: sound pz,[123,10]: pause 25
                y = y + 1: low led3
        goto bprog3
    Bprog4:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(3) > 0 THEN Counters(3) = Counters(3) - 1
        IF Counters(3) = 0 THEN
            if y = 0 then y = 3
            write 3,y
            for I = 1 to y: high led4:sound pz,[123,10]:pause 50:low led4: pause 50: next i
        if sw4 = 0 then
            pause 25                        ;debouce
            if sw4 = 0 then
                high led4: sound pz,[123,10]: pause 25
                y = y + 1: low led4
        goto bprog4
    Bprog5:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(4) > 0 THEN Counters(4) = Counters(4) - 1
        IF Counters(4) = 0 THEN
            if y = 0 then y = 3
            write 4,y
            for I = 1 to y: high led5:sound pz,[123,10]:pause 50:low led5: pause 50: next i
        if sw5 = 0 then
            pause 25                        ;debouce
            if sw5 = 0 then
                high led5: sound pz,[123,10]: pause 25
                y = y + 1: low led5
        goto bprog5
    Bprog6:
        WHILE !T0IF : WEND
        TMR0 = 225
        T0IF = 0
        IF Counters(5) > 0 THEN Counters(5) = Counters(5) - 1
        IF Counters(5) = 0 THEN
            if y = 0 then y = 3
            write 5,y
            for I = 1 to y: high led6:sound pz,[123,10]:pause 50:low led6: pause 50: next i
        if sw6 = 0 then
            pause 25                        ;debouce
            if sw6 = 0 then
                high led6: sound pz,[123,10]: pause 25
                y = y + 1: low led6
        goto bprog6
    StartCharge1:
        high TR1:
    StartCharge2:
        high TR2:
    StartCharge3:
        high TR3:
    StartCharge4:
        high TR4:
    StartCharge5:
        high TR5:
    StartCharge6:
        high TR6:
    Like you said, you've only had PBP a couple weeks ...
    Laughing would only be Rude.
    Thanks for the code!
    I think I can do something with it.
    But first I'd like to point out the WORST Basic statement ever devised.
    PAUSE xx
    It turns an amazingly fast processor into a "thumb twiddling idiot".
    Spending most of it's time doing nothing.
    If I were that chips Boss, I'd fire it.
    Granted, there are a few instances when PAUSE is required. But if at all possible, avoid PAUSE at all costs.
    Working on it ....
    PAUSE xx
    Working on it ....
    I guess I took his 720 min out of context, pretty much thought it was a stand alone app, please allow me to take For Next, Ugh Pause, and pull up my pants , . . . "thumb twiddling idiot "!, careful Darrel, that's getting pretty close to home . . . , But Darrel <B> IS ,</b> right.
    Now that's just wrong headed, I make people laugh all the time. <b>GO FOR IT !</b> You join in here, you're family.
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  2. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  3. Serious Serial Situation Setbacks...
  4. Serial Output 10 Bits
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 03:14
  5. Using 4 input to control 10 output
    Last Post: - 5th November 2004, 13:08
