18F4680 PWM 2 different frequencies
Results 1 to 4 of 4
    Question 18F4680 PWM 2 different frequencies
    Hello,
    I am using a 18F4680 to set 4 servos to center position (in main loop), also running Hardware PWM @ 38Khz, and trying to module the 38Khz @ 1ms on / 1ms off toggle. I tried setting up an interrupt but this seems to hose my main loop.
    1). what code is required to set up an interrupt on this chip body?
    2). is there an easier way like modulating the output of the 38Khz signal to give burst 1ms on / 1ms off output?
    My code is below, it works for outputting 4 servo control signals in the main loop, and hardware PWM output. I commented out the interrupt code because there is a problem with it. Basically what I wanted it to do is output a 1Khz continuous toggle via interrupt on an output pin.
    Best Regards,
    Nick
    '* Name : UNTITLED.BAS *
    '* Author : Nicholas Amireh] *
    '* Notice : Copyright (c) 2010 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 8/5/2010 *
    '* Version : 1.0 *
    '* Notes : 18F4680 *
    '* : use MPASM to compile *
    INCLUDE "Modedefs.Bas"
    DEFINE OSC 20
    ' DEFINE INTHAND myint
    ; The 18F family utilizes port latches to set/reset all I/O. Using portX = 1
    ; or portX = 0 to re/set a port will not work. This nomenclature is only good
    ; for reading port status. To alter port status use LATX = 1 or LATX = 0.
    ; Set port direction and turn off unused peripherals
    CMCON = 7 ' shut offcomparators
    TRISA = %00000000 ' Set PORTA to input "1" or output "0"
    TRISB = %00000000 ' set portB to output "0" or input "1"
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    ADCON1 = %00001111 ' bit 0 ~ bit 3 sets ports as digital I/O. 1 = digital, 0 = analog
    ADCON0 = %00000000 ' bit 0 disables A/D converter module.
    ECCP1CON = %00000000 ' bit 0 ~ bit 3 turns off capture/compare/PWM
    ' Initialize Interrupts
    'T1CON = %00100000 ' stop TMR1
    'PIR1.0 = 0 ' clear bit 0 TMR1 interrupt flag
    'TMR1H = $00 ' load timer 1 and 2 with 00, max of 65,535 * 8 prescaler before interrupt
    'TMR1L = $00 '
    'INTCON = $C0 ' enable global GIE and peripheral PEIE interrupts
    'T1CON = %00110001 ' start TMR1
    'PIE1 = $01 ' Enable TMR1 overflow interrupt
    centM con 1500 ;motor stop
    forM con 2000 ;motor forward
    revM con 1000 ;motor reverse
    trim1 con 100
    trim2 con 100
    trim3 con 100
    trim4 con 100
    Sensors var byte
    portcc var LATC.0
    poro var byte
    duty var byte
    ; initialize power on state of ports
    LATD = 0 ' force latches on portD to low
    LATA = 0
    LATB = 0
    LATC = 0
    ' asm
    'myint
    ' bsf _portcc ;diagnostic to measure frequency and duration of interrupt
    ' call _timee ; if signal is lost put everything in fail safe position
    ' retfie ; Return from interrupt
    'endasm
    'timee:
    ' LATC.0 = 0
    ' endif
    'return
    ECCP1CON = %11001100 ' bit 0 ~ bit 3 turns off capture/compare/PWM
    T2CON = %00010100 ' Turn on Timer2, Prescale=4
    PR2 = 128 ' Set PR2 to get 5KHz PWM out
    duty = 64
    ECCPR1L = DUTY
    ECCP1CON.4 = duty.0
    ECCP1CON.5 = duty.1
    Mainloop:
    Sensors = portA & %00011111
    select case sensors
    case %00000000 ; all motors stop
    portbb = %00001111
    pauseus CentM
    portbb = %00000000
    case %00000001 ; go forward
    portbb = %00001111
    pauseus form
    portbb = %00000000
    case %00000010 ; go reverse
    portbb = %00001111
    pauseus revm
    portbb = %00000000
    case %00000100
    ; wheel assingnment portbb = X X X X RL RR FL FR
    portbb = %00000011 ; go left
    pauseus revm
    portbb = %00000000
    portbb = %00001100
    pauseus form
    portbb = %00000000
    case %00001000 ; go right
    portbb = %00000011
    pauseus form
    portbb = %00000000
    portbb = %00001100
    pauseus revm
    portbb = %00000000
    case %00010000 ; spin in place
    portbb = %00000101
    pauseus form
    portbb = %00000000
    portbb = %00001010
    pauseus revm
    portbb = %00000000
    end select
    pause 16
    goto mainloop
    Default Re: 18F4680 PWM 2 different frequencies
    I went through the data sheet but I seem to be missing something. I can't get the interrupt to work. Code enclosed.
    '* Version : 1.0 *
    DEFINE OSC 20
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    T2CON = %00000101 ' %00000100 = TMR2 ON 1:1 pre-scale
    ' %00000101 = TMR2 ON 1:4 pre-scale
    ' %00000110 = TMR2 ON 1:16 pre-scale
    TMR1H = $FE ' load timer 1 and 2 with 00, max of 65,535 * 8 prescaler before interrupt
    TMR1L = $00
    RCON = %00011011
    INTCON = %10100000 ; bit 5 enables/disables timer1 interrupt
    INTCON2 = %10000100
    INTCON3 = %00000000
    PIE1 = %00000001
    IPR1 = %00000001
    trim1 con 100
    trim2 con 100
    trim3 con 100
    trim4 con 100
    Sensors var byte
    duty var byte
    W_TEMP var BYTE bank0 system
    status_temp var BYTE
    bsr_temp var byte
    portcc var LATC.0
    portbb var LATB
    LATA = 0
    LATB = 0
    LATC = 0
    goto intro
    asm
    myint
    movwf W_TEMP
    movff STATUS, _status_temp
    movff BSR, _bsr_temp
    movlw 0x01
    xorwf LATC,f ; toggle
    movff _bsr_temp, BSR
    movf W_TEMP, w
    movff _status_temp, STATUS
    endasm
    intro:
    duty = 64
    ECCPR1L = DUTY
    ECCP1CON.4 = duty.0
    ECCP1CON.5 = duty.1
    Mainloop:
    select case sensors
    portbb = %00001111
    pauseus CentM
    portbb = %00000000
    portbb = %00001111
    pauseus form
    portbb = %00000000
    portbb = %00001111
    pauseus revm
    portbb = %00000000
    case %00000100
    pauseus revm
    portbb = %00000000
    portbb = %00001100
    pauseus form
    portbb = %00000000
    portbb = %00000011
    pauseus form
    portbb = %00000000
    portbb = %00001100
    pauseus revm
    portbb = %00000000
    portbb = %00000101
    pauseus form
    portbb = %00000000
    portbb = %00001010
    pauseus revm
    portbb = %00000000
    end select
    pause 16
    goto mainloop
    I know little of interrupts, but the first place I would start is here:
    http://www.picbasic.co.uk/forum/showthread.php?t=3251
    Thanks Robert for pointing me to the thread. I am extremely frustrated with this chip body. It is too many layers of interwoven configurations. I mean a simple G%D D&^N interrupt is a chore....sigh. I am stuck trying to get this to work....
    Nick
