Serial Communication with PIC16F877A
Results 1 to 17 of 17
    Do you have a MAX232 or similar between the PIC and PC?
    If you do not have one, try SERIN2/SEROUT2 using inverted mode.
    Dec 2008
    Charlottesville, VA
    Question Yes
    Yes I have a MAX232 on the ICD I've built... it should also work as my serial communicator for this purpose as well... This is the number on the chip:
    69CT01M
    MAX232IN
    TTL to CMOS converter...
    any ideas?
    Morris Beasley
    Manufacturing Test Technician
    B.S. Industrial Technology (2007)
    For more information on our robotics, please visit:
    http://www.ish-electronics.webs.com
    Serial data to a PC should always be 8 bits.
    DEFINE HSER_BITS 9 ; won't work
    Missed this the first time I looked at it.
    DEFINE HSER_BITS 9
    Scratch the above line
    Dec 2008
    Charlottesville, VA
    Question Modifications...
    I have scratched the line as you suggested... however, it still isn't working. If I try to transmit the example in my code, which is A369621... I don't receive anything back at all. Also, if I don't transmit anything and the USART times out, I receive this: ¬ºê*ë... any other ideas?
    Do I have to set PORTC as this:????
    TRISC=%11000000
    I'm a little confused on the correct settings to get the USART to function properly.
    Last edited by mcbeasleyjr; - 26th May 2009 at 23:25. Reason: another question....
    Morris Beasley
    Dec 2008
    Charlottesville, VA
    Question tried...
    I copy and pasted the code you provided me but had no luck with it...
    Morris Beasley
    Can you post your schematic and/or a picture of your setup. I think it is down to a hardware problem now.
    Caps on the 232?
    Cable is straight through?
    Usb to serial converter?
    Real serial port?
    Port on PC is known to be good?
    Hold one hand in the air while touching you big toe?
    Could be anything now.
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 03:49
  2. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 20:02
  3. Bootloader,MCSP and Serial communication
    By surfer0815 in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2006, 10:52
  4. Serial Communication using 12F629
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th March 2005, 04:24
  5. Replies: 8
    Last Post: - 11th November 2004, 20:08
